O/T- Opening Email Issues
Submitted: Monday, Sep 01, 2008 at 20:16
ThreadID: 61303 Views:2566 Replies:8 FollowUps:11
Evening All,
lately i am recieving more and more emails that i cant open,it spits out - application not available/search for application or set in the option control panel. where is it? me not find this one,even doing a search i cant find it. up until a couple of months ago i never had an email i couldnt open,but now !!!! this is one for the computer gurus not a home hack like me.any thoughts or suggestions short of throwing it out the window would be appreciated. cheers Paul
Reply By: Member - Arthur V (VIC) - Monday, Sep 01, 2008 at 20:35
Install Thunderbird its free:
http://www.mozilla.com/en-US/thunderbird/
AnswerID: 323329
Follow Up By: TD100 - Monday, Sep 01, 2008 at 21:06
tried it then dumped it, pain in the bum to use IMHO and still could not open the emails- thanks anyway Arthur
FollowupID: 590427
Follow Up By: Member - Arthur V (VIC) - Monday, Sep 01, 2008 at 21:26
Sounds like a typical Windows system, after a few months everything slows down things won't open. This is the main reason I gave Windows away about two year ago and install Linux Ubuntu and have not looked back since. The best part of all is that it is free and far superior to Windows, but yes stick with Windows I suffered for ten years before I made the switch.
Then remember there are all those viruses and security issues in Windows which you don't have in Linux and yes don't forget to defrag your hard drive this is require in a Windows system but something I have not done in Linux for two years.
FollowupID: 590435
Reply By: Member - Graham H (QLD) - Monday, Sep 01, 2008 at 20:48
Well you are asking us to do brain surgery blindfolded.
What operating system are u using and what program do u use to open the emails.
AnswerID: 323335
Follow Up By: TD100 - Monday, Sep 01, 2008 at 21:04
hahaha yeh that will probably help too! XP Home and Outlook Express Thanks Graham
FollowupID: 590426
Follow Up By: Member - Graham H (QLD) - Monday, Sep 01, 2008 at 21:30
Is it when you open Outlook express you get the message or does OE not open and windoze is looking for it .
You must give us a specific description of the problem to get a reasonable fix for it
Who is your internet provider
Go to your internet providers home page and go to webmail and read it from there and then do the following
Go to outlook express/tools /accounts/properties and check all the settings.
Write down the settings on the connection page if you arent familiar with them
In the advanced pane click the box "Leave a copy of messages on the server".
This will mean that you dont lose any if you delete them by mistake.
However you will have to go into your webmail and clean it out once a month or so depending on how much mail you get.
IInet gives me about 500 before it bounces them back.
If you dont mind losing any that you have u can go into Control panel/ ad remove progs. On the left go to add remove windows components.
Go down to outlook express and unclick it. This will uninstall it COMPLETELY messages contacts and all Restart and go back to same palce and click it This will reinstall it hopefully in a working condition. Do the leave copy bit again
If you want to retain the messages and settings and contacts Email me and I will send you a program called Outlook express backup & restore This will save all messages and contacts.
I cant tell you where to get it or I would have to kill you
FollowupID: 590437
Reply By: Member - Doug T (NT) - Monday, Sep 01, 2008 at 21:19
Untick the checks
Image Could Not Be Found
AnswerID: 323350
Follow Up By: TD100 - Monday, Sep 01, 2008 at 21:44
Thanks Doug but they are unticked already
FollowupID: 590445
Reply By: MrBitchi (QLD) - Tuesday, Sep 02, 2008 at 07:41
In My experience your problem is Outlook Express. It doesn't handle attachments very well. Upgrade to the full outlook that comes with Office and you'll have no more problems.
Yes Doug, I know it works for you, just passing on my experience..
AnswerID: 323396
Follow Up By: Member - JohnR (Vic) - Tuesday, Sep 02, 2008 at 18:15
I am with you John. Outlook Express is lighweight only should be capitalized.
FollowupID: 590561
Reply By: Member No 1- Tuesday, Sep 02, 2008 at 07:59
i notice that some attachments on my system wont open at first...I save them and then they open...i have no idea why.....
AnswerID: 323402
Follow Up By: Keith_A (Qld) - Tuesday, Sep 02, 2008 at 09:01
Hi Uno - I also had to solve that problem.
Solution : When you click on an attachment (eg a file such as a document or picture or PDF etc), the Email Program needs to know what application (program) to use to open that file.
I use Thunderbird as my Email program, and under OPTIONS - click Attachments, then click VIEW And EDIT actions. Here you will see a list of file types, and the program you want EMAIL to use, to open them.
I expect all email programs would have a similar function...Keith
FollowupID: 590506
Reply By: Member - William B (The Shire) - Tuesday, Sep 02, 2008 at 09:56
Hi Paul,
Just a quick thought,
are the attachments in the winzip format.
eg. for example "picture.zip"
or some other sort of compression software, winrar etc.
or maybe a imaging software that cannot be opened by your default imaging software ?
Maybe you can describe the attachment name?
William
AnswerID: 323422
Reply By: OldMike2 - Tuesday, Sep 02, 2008 at 12:39
If you mean that you can't open attachments, then that is a different thing to being not able to open email.
I suspect that the problem is with attachments that are actually MS Word documents.
The problem occurs when you try to open MS Word 2007 documents with an earlier version of MS Word. If the file extension is .docx rather then .doc, then that is the problem.
Solution: 1) upgrade your version of MS Office to 2007
or
2) Ask the sender to save the documents in an earlier word format, or save them in .rtf format
If word documents are saved in .rtf format, any version of MS Word can read them.
I have seen quite a lot of this problem lately.
Hope this helps
Mike
AnswerID: 323439
Follow Up By: Member - Arthur V (VIC) - Tuesday, Sep 02, 2008 at 12:49
You can also install Open Office and then install an add on that will read Docx files. Why pay MS Hundreds of dollars when Open Office is free and does the same thing.
http://download.openoffice.org/
FollowupID: 590522
Follow Up By: Ozboc - Tuesday, Sep 02, 2008 at 17:46
You pay MS for the apps ? , guess someone has too ......
Boc
FollowupID: 590555
Follow Up By: Member - Arthur V (VIC) - Tuesday, Sep 02, 2008 at 18:47
Hi Ozboc,
I've seen what happens when a search is done for a crack and then the computer is taken over by a some virus. If you want to get everything for free and it all works without security issues, try Linux
FollowupID: 590563
Reply By: TD100 - Tuesday, Sep 02, 2008 at 20:57
Thank You for all your replys, i tried several of the responses and found open office works a treat. so i will run with that one for now. cheers Paul
AnswerID: 323519
Follow Up By: Member - Arthur V (VIC) - Tuesday, Sep 02, 2008 at 21:06
Hi Paul,
Great to hear it's all working for you and best of all Open Office is Free!!!
FollowupID: 590594
