uhf gme programming cable
Submitted: Wednesday, Sep 03, 2008 at 08:28
ThreadID: 61345 Views:4016 Replies:2 FollowUps:4
gday all
does anyone know about these, I HAVE A GME 4400 UHF & was just wondering what else i could add to the uhf that is worthwhile the cost of the connector?
url=http://cgi.ebay.com.au/GME-Programming-Cable-TX3400-TX4400-TX3600-TX3800_W0QQitemZ280261168645QQihZ018QQcategoryZ1501QQssPageNameZWDVWQQrdZ1QQcmdZViewItem]Site Link[/url]
Reply By: Member - Mark G (NSW) - Wednesday, Sep 03, 2008 at 08:29
Site Link
AnswerID: 323576
Follow Up By: Robin Miller - Wednesday, Sep 03, 2008 at 19:19
Hi Mark
Its probably a waste of time but I brought it anyway.
If it works out you can share the cable as its likely to be rarely used.
I note that the software link is invalid , and getting software may be an issue.
The chance I am taking is because the 4400 came out with defective software in the CTCSS function and I believe thers a possibility that its time constant can be changed.
If interested keep in touch
FollowupID: 590778
Reply By: Dave(NSW) - Wednesday, Sep 03, 2008 at 12:08
Mark,
You can set extra frequencies in a 4400 with out a cable connector, It should show you in the instruction book and just goggle NSW or where ever Police or Emergencey services radio frequencies then pick out the areas you want to listen to,I think you can get 20 extra listen only channels.
Cheers Dave...
GU RULES!!
AnswerID: 323607
Follow Up By: Member - Mark G (NSW) - Wednesday, Sep 03, 2008 at 12:13
DAVE
yeah,got all that worked out,i just dont knwo what else this gadget ,with the internet can do.it says about doing A LOT MORE in the EBAY ad,just wondering what?
cheers.
FollowupID: 590678
Follow Up By: Dave(NSW) - Wednesday, Sep 03, 2008 at 12:49
Mark
Send the guy a message through EBay and ask what the lot more is, If he doesn't say his just trying to make it sound worthwhile buying.
Cheers Dave...
GU RULES!!
FollowupID: 590680
Follow Up By: SteveL - Wednesday, Sep 03, 2008 at 19:01
The only thing useful you can do with the programming cable is change your selcall number.Note that you also need the factory software as well as the cable and you need a computer that will run the software.(i.e. it probably won't run with some later operating systems and faster computers)-Steve
FollowupID: 590770
