power from vehicle to van
Submitted: Wednesday, Sep 03, 2008 at 14:14
ThreadID: 61354 Views:2604 Replies:5 FollowUps:3
Hi guys , I have just bought my first and it has a 210 hr battery in it which charges from the vehicle through the normal 7 pin plug and also 240.
I have seen lots of adds that say anderson plugs charge the battery. Should i leave it charge from the normal 7 pin or is an anderson plug the best way to go.
Thanks in advance
patrolman
Reply By: ajd - Wednesday, Sep 03, 2008 at 14:44
I have a patrol with a Pioneer camper which charges via an anderson plug which is wired directly to the second battery in the car.
AnswerID: 323624
Reply By: Member - Mark R (QLD) - Wednesday, Sep 03, 2008 at 15:17
Hi Patrolman,
I also have a patrol with a aussie swag camper with 2 deep cycle batterys. The problem with the 7 pin is it dosn't give enough power to charge properly. I was informed from the camper firm to make sure the cable to the anderson plug is a 6BS wire which is a charging wire. It does cost a bit more but we found it well worth it. We have our camper set up to run our 80lt Waeco from the 2nd car battery when we are driving & then switches over to the camper battery when we stop, this allows the camper batterys to charge up quicker.
regards,
Mark R
AnswerID: 323633
Follow Up By: Ted G - Wednesday, Sep 03, 2008 at 16:31
Hi patrolman
I have an 18/6 full Caravan with a battery fitted, and an Anderson plug with heavy duty wiring.
It is the only way to go as the 7 pin won,t work very well if you are running a fridge as well as charging the battery.
regards
Ted
FollowupID: 590724
Follow Up By: Member - DAZA (QLD) - Wednesday, Sep 03, 2008 at 16:52
Anderson Plug is the only way to go.
FollowupID: 590730
Reply By: Member - Philip S (SA) - Wednesday, Sep 03, 2008 at 17:38
Electrics is not my strong suit, but when we bought our Kvan which has big bank of deep cycle AGM batteries in it it was emphasised very strongly that one should have at least 14volts at the Anderson plug, or the available amp hours would be significantly reduced, and worse, shorten the life of the batteries which are expensive to say the least. Test shows about 14.3 volts which is good.
Don't believe you'd get that through the conventional 7 pin plug, IMO.
AnswerID: 323652
Reply By: Mainey (wa) - Wednesday, Sep 03, 2008 at 20:11
As all the guys above also state ONLY an Anderson plug (not 7 pin plug) will be able to handle the physical cable size and the high current required to maintain a full charge in your Van.
The cable size has to be sufficiently large in (wire) diameter to be able to deliver the current with zero Voltage drop to your Van battery.
Mainey . . .
AnswerID: 323701
Follow Up By: patrolmann - Thursday, Sep 04, 2008 at 15:20
thanks for that guys , guess its off to the auto lekky to have an anderson plug added. Guessing a couple of hundred $$$$$
patrolman
FollowupID: 590859
Reply By: Jimbo 2211 - Thursday, Sep 04, 2008 at 20:21
Hi patrolman
I am curious which wire is used to provide auxiliary power to the van when using a 7 pin plug of either the round or flat types.
My interpretation of the connections as listed do not seem to have a spare wire except the reverse wire. Is this used to power the van? If so it will certainly be of a gauge suitable for lighting and not for charging or van power.
All the other connections are specified to provide compliance with essential lights and indicators. The brake is needed for trailers exceeding 750 kg and is not available.
It appears to me that you must use an Anderson plug or a 12 pin double flat connector and suitable heavy gauge wire (6mm) to get any significant auxiliary power to the van.
Round heavy duty plug & socket
1 earth - white
2 reverse - black
3 left hand turn - yellow
4 stop - red
5 right hand turn - green
6 tail, clearance, side markers - brown
7 brakes - blue
7 pin flat plug & socket
1 left hand turn - yellow
2 reverse -black
3 earth - white
4 right hand turn - green
5 brakes - blue
6 stop - red
7 tail, clearance, side markers - brown
Cheers...Jimbo221
AnswerID: 323836
