Broken wheel stud 99 model Patrol
Submitted: Wednesday, Sep 03, 2008 at 21:47
Featherfoot
Hi all, I have a question for the Patrol gurus on EO.
One of my rellies has a broken rear wheel stud on a 99 petrol auto patrol and not in much of a rush to get it fixed, so before someone gets hurt I told him I'd fix it for him.
Could someone point me in the right direction to get the hub off so I can get to the stud to push it out and fit a new one. Any special
tools or large sockets required?
Thanks in advance
Gary
Reply By: Member - Ed. C. (QLD) - Wednesday, Sep 03, 2008 at 23:14
G'day Featherfoot,
I'm pretty sure it's a simple matter of removing the brake caliper, and the disc rotor should come straight off exposing the flange/studs.. no special
tools required..
Not sure about the early (4.5) petrols, but if it's the same as the 4.8, they have a combination disc/drum arrangement, w/- the drum part being the
park brake.. On the diesels, it's just a bare flange...
Actually had
mine (4.8 auto) off not so long ago to replace brake pads, but I must say as I wasn't looking at replacing studs, I didn't really pay attention to how easy (or otherwise) it would be to push those studs back with that drum brake assy there:(
(ya don't really wanna be bashin' at 'em with a hammer in situ)...
One way to find out I guess, is to open 'er up & go from there;-))
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
323732
Follow Up By: Vivid Adventures - Thursday, Sep 04, 2008 at 09:00
I've only ever done it on the side of the road... and too many of them... and once for a Paj and once for a Patrol, but hammers were necessary on all occasions... but then dust and stuff were the order of the day.
590829
Reply By: Cupie - Thursday, Sep 04, 2008 at 09:04
G'day Featherfoot ...
You might get a solution by posting your enquiry on the
forum "patrol4x4.com"
cheers .. G
323756
Follow Up By: Featherfoot - Thursday, Sep 04, 2008 at 19:22
Thanks for your reply Cupie,
Tried to register on that site so I could post an enquiry but there is a problem registering on that site apparently
Gary
590892
Reply By: Member - Duncs - Thursday, Sep 04, 2008 at 09:37
I don't know about the Patrol, even though I have one, but I have done this job on a couple of vehicles and did not have to remove anything other than the wheel.
Usually just knock the brocken stud out with a hammer and a punch. On all the vehicles I have worked on there is a gap in the backing plate somewhere and by rotating the wheel so the broken stud lines up with this gap you can get the broken bit out and fit the new stud.
I have had trouble reaching to get the new stud in, this can be overcome by sticking the new stud to the end of an extension bar, a suitabley sized socket will hold it there as will Blu Tack or gaffa tape.
The last time I did it was on a Honda Civic at the side of the road just south of Hattah. It broke 2 studs on the front wheel so I took one from each of the rear
wheels to put a full set on the front, where all the work is done.
Duncs
323759
Reply By: Featherfoot - Thursday, Sep 04, 2008 at 19:26
Thanks all for your replies.
I'll take a look as soon as I can get hold of the vehicle.
Gary
323824
