OziExplorer 3D
Submitted: Friday, Sep 05, 2008 at 21:46
ThreadID: 61431 Views:2386 Replies:1 FollowUps:3
Has anybody got any comments on the 3D version - it's advantages and disadvantages .
I run the old non 3D version now . Would I just upgrade this or would I have to uninstall it and install the new 3D version ?
Thanks ,
Willie .
Reply By: pt_nomad - Friday, Sep 05, 2008 at 22:39
The 3D is an additional program. It is a good novelty but I find I dont use it any more as is does not add that much.
You need to by the 9 second DEM info to make it worthwhile.
It enable you to do a plot on a may in 2d and then view the map and plot streched over a 3d wire frame. All very intersting but I find time does not allow such games any more :)
Paul.
AnswerID: 324058
Follow Up By: The Explorer - Friday, Sep 05, 2008 at 23:29
"You need to by the 9 second DEM info to make it worthwhile"
No you don't - free NASA 3 second DEM data is available here and has been for years....
SRTM Download
Much better than the 9 second Aus data.
3D is great, if you have a use for it. If you don't then it is of novelty value only. Only one person can decide if it is of any use to you and that is you. It certainly looks good when used on the Pilbara and Kimbelrey maps sets :)...bit boring in flat areas.
FollowupID: 591107
Follow Up By: pt_nomad - Saturday, Sep 06, 2008 at 06:21
Thanks Greg,
I didnt realise the down graded shuttle radar data was publicly available - I'd better update, 3 second will certaily improve terrain relief.
Paul.
FollowupID: 591113
Follow Up By: The Explorer - Saturday, Sep 06, 2008 at 09:31
No worries
There is actually an automatic file download function inbuilt into OziExplorer (when you have installed the 3D program) which will download the relevant 3 sec height data file for the map you have currently open.
Hit the 3D/Elevation menu and the second item from the bottom is Download SRTM Height Data (World 3 Second).
Instructions on use of data 9and other data sets is here
Ozi 3D Height Data
FollowupID: 591134
