Fitting Brake Controleer to new Toyota 70 Series
Submitted: Saturday, Sep 06, 2008 at 13:19
Member - Norm C (QLD)
I've got my new 70 Series and have started the process of converting it into the touring vehicle we bought it for.
Currently fitting one of the new Prodigy P3 brake controllers. I'm buggered if I can identify or access the wires to the brake light switch at the brake pedal.
With the location of the fuse box, I don't think I can connect there either.
Plenty of people must have fitted brake controllers to this vehicle. I'm after the benefit of your experience. Where can I connect that will access the cold side of the brake light switch?
Norm C
Reply By: mr fixit - Saturday, Sep 06, 2008 at 13:33
Well its probably got cruise control. The safest way is to run a wire back from the tail lamps.
324109
Reply By: mr fixit - Saturday, Sep 06, 2008 at 13:34
Sorry I ment to say run a wire back from the stop lamps
324110
Reply By: toyocrusa - Saturday, Sep 06, 2008 at 14:21
Definitely run the wire from the rear of the vehicle.I checked with Tekonsha technical in
Melbourne when I fitted one to my brother's 200 Sahara and my own Prado. They said the voltage is "filtered" at the rear and will not affect any electronics.
324116
Follow Up By: Member - Norm C (QLD) - Saturday, Sep 06, 2008 at 17:39
As I said in a follow up to Autosparky below, I was a bit worried about voltage drop, with current running from front, back to stop light, forward to controller, then back again to brakes.
But if Tekonsha has recommended it, I guess it is OK.
I assume your brakes are working OK?
I'll be towing a 3,500 KG dual axle caravan, so brakes are pretty important.
Norm C
591171
Follow Up By: toyocrusa - Saturday, Sep 06, 2008 at 20:50
Hi Norm. As autosparky said. The wire from the brake light is a signal or activation wire so only needs to be a light gauge wire(I used 2mm) The wire to the caravan brakes carries a much higher voltage so needs to be around 6mm. This was all recomended by the Tekonsha guy I spoke to on the phone.( I rang the distributor in
Sydney who passed me on to this fellow in
Melbourne,He seemed to know his product) The 200 Cruiser is towing a 3 tonne Boroma Caravan and has had no problems as yet. He is currently staying at Pialba if that happened to be near you I could put you in contact if need be.Regards, Bob.
591208
Follow Up By: Member - Captain (WA) - Sunday, Sep 07, 2008 at 22:17
Hi Bob,
I wired up my P3 in my 200 but connected the brake wire off the pedal switch (its the solid red wire out of the 4 in the switch). I thought about bringing the wire back from the rear plug (had to run a the brake power wire anyway) but was concerned that the cruise control may not cancel if I manually applied the trailer brakes.
Also, the 200 has a relay box in the back for the lights (it has LED brake lights and the wiring is too light to tap directly into) so not sure if the brake lights are activated from a manual brake application.
If the brake controller is wired from the rear trailer lights, do you know if the cruise control is cancelled and/or the brake lights activated when manual trailer braking is used?
Captain
591361
Follow Up By: toyocrusa - Monday, Sep 08, 2008 at 06:57
Hi Captain. I wired this unit into my brother's Sahara a couple of months ago when he was visiting us in NSW. He is currently in Qld so have forwarded your email and will reply when I get a response. I'm not sure if he would have used cruise control towing as the van is a 3 tonne Boroma but the brake lights definitely activate in manual mode. Regards,Bob.
591392
Follow Up By: toyocrusa - Saturday, Sep 13, 2008 at 20:59
Hi Captain. We have finally got to test both vehicles regarding the controller manually operated for brake light and cruise control operation. On my Prado the brake lights work and the cruise control cancels. On the 200 neither the brake lights work nor does the cruise control cancel so looks like it has to be wired in before the relay. Thanks for bringing that to our attention. It has me wondering now, how does it cancel the cruise on my Prado when I have a four wire switch at the pedal. Regards,Bob.
592235
Follow Up By: Member - Captain (WA) - Sunday, Sep 14, 2008 at 11:44
Hi Bob,
Your Prado doesn't have a relay box in the trailer harnass (200 has LED lights and factory wiring is too thin, hence the relay box). Thus tapping in at the rear is effectively tha same as tapping in at the switch.
In the 200, the relay acts as a "one way" switch and thus when the electric brakes are activated there is no "reverse flow" back to the brake switch if you have tapped in after the relay box.
I hope that explanation makes sense.
Captain
592337
Follow Up By: toyocrusa - Sunday, Sep 14, 2008 at 16:45
Hi Captain. I follow all that you have explained OK. I just don't get how the controller cancels my cruise(on the Prado) when the cruise cancel is on another part of the brake light switch separate from the brake light wire. Just curious. I'll talk to a local sparky when I get a chance. Will also get back to the Tekonsha guy and let him know about the 200 relay.Thanks,Bob.
592362
Reply By: Dunaruna - Saturday, Sep 06, 2008 at 15:30
The easiest way to connect is at the trailer base plug. You need to run the blue back to pin 5 anyway, just use twin core and connect the red to pin 6. That way you eliminate any potential problems.
324120
Reply By: autosparky - Saturday, Sep 06, 2008 at 16:56
pull out the kick panel on drivers side remove fuse box 2x 6mm bolts look for the green/white trace wire
324127
Follow Up By: Member - Norm C (QLD) - Saturday, Sep 06, 2008 at 17:34
I was going to do that, but it seemed a bit daunting.
I thought - what if some wires come loose while I'm stuffing around, I'll be buggered then.
Given your screen name, I assume you have done this on a 70 Series a few times, and it is simple to do with no risk of me ending with a heap of loose wires, or otherwise stuffing things up???
Otherwise, without advice from an 'expert', I was going to do as others have suggested and run from the stop lights at the back. But that seems a bit nutty. Getting the power from the rear and sending it to the front to activate the controller, then sending it back to the rear to activate the brakes. I was a bit worried about voltage drop over that distance, but don't know how serious an issue that is with electric brakes.
591169
Follow Up By: gasgas - Saturday, Sep 06, 2008 at 17:55
Hi Norm,
Voltage drop is no issue here, the brake controller has a permanent 12v connected, the connection to the brake light is merely providing the controller with a signal to then apply voltage to pin 5 of the trailer plug which in turn applies power to the electric brakes.
As said previously, run a twin to the rear of the vehicle....1 core to pin 5 and tap the other into the brake light at the tail light.
591176
Follow Up By: autosparky - Saturday, Sep 06, 2008 at 17:55
my adress is waconsofraptors@iinet.net.au send your ph no ican talk you thru it i have been an autosprky for26yrs , new vehicle wiring harnesses dont fall apart any more
591177
Follow Up By: autosparky - Saturday, Sep 06, 2008 at 18:08
do use 5mm twin it will assure you of no volt drop and you will have a spare wire you can use for aux power etc if needed to caravan or trailer. number5 pin for elec brakes if number2 pin is free and you dont have reverse lights hooked to trailer , i can be used for ahot wire thru a fuse
591180
Reply By: Member -Pinko (NSW) - Saturday, Sep 06, 2008 at 18:08
I fitted my 70 series with a Prodigy. I picked up the wire from the footbrake power at the footbrake switch on the pedal. On this this model Toyota have retained that power outlet like the 60 series and 80 series which has LIVE, ACC. and IGN. with a recommended circuit breaker on the power side.
Stan
324138
Reply By: Ray - Sunday, Sep 07, 2008 at 09:20
I've fitted quite a few brake controllers in my time and have always connected to the brake light in the rear. You have to run one wire to the rear so why not two? It saves jiggering about around the brake peddle.
324213
Reply By: Gronk - Sunday, Sep 07, 2008 at 10:37
Any auto lecs out there may want to correct me, but I don't believe the brake wires are "filtered " to protect eleltronics ?
It has been stated many times before......the wire for the brake light goes from front to rear and it doesn't matter where abouts along that wire you take a feed....it's still the same wire !!
If it interfers with electronics if hooked up under the dash then it will do the same if hooked up at the rear !!
324232
