Welding on Caravan Frame - Precautions
Submitted: Saturday, Sep 06, 2008 at 18:35
tuck 01
Evening all.
I have to get a bit of welding done on the caravan. My
young bloke is bringoing his little MIG around to do it.
Can anyone tell me if I have to take precautions like disconnecting the batteries or anything else to avoid damage to the televison, DVD player etc in the van?
Thanks in advance.
Jeff
Reply By: Member - shane (SA) - Saturday, Sep 06, 2008 at 18:39
I always disconnect the batter when welding, also watch out for any transfer heat up through the floor.
keep fire extinguisher handy.
cheers shane.
324145
Reply By: oldtrack123 - Saturday, Sep 06, 2008 at 18:45
The most important thing is to make sure you have a
bright metal suface ON THE PART YOU ARE WELDING & put the earth clampTHERE[ as close as possible], also unplug the tv aerial , ,if you have bats in the van disconnect earth cable
324147
Reply By: Member - Doug T (NT) - Saturday, Sep 06, 2008 at 19:10
Jeff
Just in case he don't know, if welding on the A-Frame or along the chassis , do the weld along the frame only, not across , that avoids cracking,
324154
Reply By: Nav 8 - Saturday, Sep 06, 2008 at 19:20
And check for any electrical wiring running through the chassis that can melt with the heat,, Nav.
324155
Reply By: tuck 01 - Sunday, Sep 07, 2008 at 06:09
Thanks for the replies.
The welding is not on the frame but is on the gerry can holders either side of the gas bottles. Just a couple of brackets to mount a frame to carry a space case.
Batteries and TV aerial disconnect will be the go. And, of course, will remove the gas bottles.
324190
Reply By: obee - Sunday, Sep 07, 2008 at 20:52
any scientific evidence out there? Many years ago there was a problem with alternators but not for many years since. So I was told by a techie. If I had any doubts I would go to the experts and give this
forum a big miss unless the info is backed up with credentials.
owen
324286
