GU Patrol Door Extension Bracket
Submitted: Monday, Sep 08, 2008 at 11:36
ThreadID: 61486 Views:3101 Replies:5 FollowUps:4
Morning all, This post is just to let Patrol owners know about the passenger side barn door on the GU's. As you know the door doesn't open quite far enough especially of you have a storage system. I saw in the trader section of this site a new bracket that allows the door to open straight. I purchased one and fitted it on the weekend and I am very happy with it. The door now opens right out and allows easier access. When you see it you will wonder how much difference it will make, but it does. It was very easy to fit a comes with instructions. Cheers, Glenn
Reply By: Tasrat - Monday, Sep 08, 2008 at 12:31
Good to hear Glenn, I just "put one in my cart" at the shop only an hour ago. So feed back very timely.
Cheers and thanks Paul
AnswerID: 324366
Reply By: Waynepd (NSW) - Monday, Sep 08, 2008 at 13:13
Gday Chambo,
I saw a picture of that bracket somewhere and couldn't remember where....LOL.
I thought it was in last months 4wd action mag....
where does it fit?
AnswerID: 324371
Follow Up By: Chambo - Monday, Sep 08, 2008 at 13:23
Hi Waynepd,
You take off the bracket that's bolted to the body and angle grind the bottom of the pin. Push the pin out and put on the new bracket which is longer allowing the door to open further. Takes about 20 min to fit. The longest part is carefully grinding out the pin. Cheers, Chambo
FollowupID: 591432
Follow Up By: Waynepd (NSW) - Monday, Sep 08, 2008 at 13:36
Sounds like another project coming up thanks Chambo..
FollowupID: 591433
Reply By: ExplorOz - David & Michelle - Monday, Sep 08, 2008 at 13:42
Glenn,
It is not in the trader system it is actually in the Shop system - A direct link for anyone interested is Nissan Patrol GU Rear Door Bracket Extension
AnswerID: 324372
Follow Up By: Chambo - Monday, Sep 08, 2008 at 15:04
Yes your'e right of course. Sorry if I confused anyone. Have recently put the Eagle on the trader and had it stuck in my mind.
FollowupID: 591455
Reply By: Patrol22 - Monday, Sep 08, 2008 at 19:40
That's a good price too folks...I paid $30 for mine from Black Widow about 3 years ago.
AnswerID: 324437
Reply By: Patrol_Driver - Monday, Sep 08, 2008 at 19:57
Will this fit the current model Patrol with the larger tail-lights?
AnswerID: 324443
Follow Up By: Member - Ed. C. (QLD) - Monday, Sep 08, 2008 at 22:01
yep
Confucius say.....
FollowupID: 591546
