Bore & Pump on the Sandy Blight Junction Track .
For those heading out on the Sandy blight, it's important to know that the bore and handpump half way down the track is producing fairly salty water at present. The pump is working fine and the water is clear but very salty. Don't mix it with your good drinking water! Forgot to mention this in my track reports previously and haven't seen the fact highlighted since.
Mick
Reply By: ExplorOz - David & Michelle - Monday, Sep 08, 2008 at 12:56
Hi Mick O - thank for that info. We are just about to release a trek note for this track - once it is "live" on the site, we can link your post into the trek as a feedback so it will be visible to all that read it. I would presume that water conditions may change, hence we may not decide to add it to the permanent text on the trek note. MM
AnswerID: 324368
Follow Up By: Member - Mick O (VIC) - Monday, Sep 08, 2008 at 15:17
Cheers D & M.
Mick
FollowupID: 591458
Follow Up By: Member - Stephen L (SA) - Tuesday, Sep 09, 2008 at 19:39
Hi Mick,
I know the bore that you are talking about. A good point to make here is that any person that undertakes any serious outback trip, must plan their water requirement correctly, and not rely on any bores for topping up supplies. As with any bore, the water quality would most times always be the same, as the aquifers from where the water is drawn do not change in quality, except where there is high rainfall to so call flush the water out.
Also for medical reasons, there could be serious health problems in taking water from an unknown source. The best way is to plan your trip, as you have done. Any new comers to outback travel should travel with someone who has experience in remote travel.
FollowupID: 591656
Follow Up By: Member - Mick O (VIC) - Tuesday, Sep 09, 2008 at 22:10
Too right Stephen.
I was amazed on this trip to discover just how many water points marked on maps (the Hema in particular) were either unserviceable or producing undrinkable water. I hope more people here will post them with their trip reports for the benefit of us all.
Mick
FollowupID: 591694
Follow Up By: ExplorOz - David & Michelle - Wednesday, Sep 10, 2008 at 13:16
In fact, if people where to use the Places system to provide the details against the exact waypoint then we can "sell" this info back the mapping publishers! Places is the ideal section on ExplorOz to make notations about conditions as this automatically feeds back into our trek notes etc. Thank you for a great post!
MM
FollowupID: 591768
