effect of fuel cooling
Submitted: Tuesday, Sep 09, 2008 at 23:32
qubert
there is plenty of data stating the effects of cooler air on the combustion process. but is there any research done on the effects of cooler
fuel ( especially diesel ) . obviuosly if you can keep most objectives constant/predictable then its going to be more efficient , but is
fuel temp really important . ( i was / am going to run my diesel through a small 'cooler ' before it gets to the pump .)
Reply By: Waynepd (NSW) - Tuesday, Sep 09, 2008 at 23:58
Hi Qubert,
Don't know the answer to your question but if you are going to cool it beware the cloud point on diesel. This is the temperature where it begins to wax up.
324612
Reply By: alfclp - Wednesday, Sep 10, 2008 at 00:06
Provided the
fuel in not cooled to the cloud point, then physics would have it that as the
fuel gets colder the volume contracts. Thus if the injectors are admitting a fixed volume to the cylinders then the mass of
fuel increases and hence the number of carbon atoms. Thus with more
fuel to burn, more energy is released to provide power provided also that the stoichiochemical ratio is maintained..
324613
Reply By: qubert - Wednesday, Sep 10, 2008 at 00:24
yes that is all correct. and i know that the old 2 stroke gm's ( 892 , 692 , 1692 , 671 etc etc ) they had a problem with running hot
fuel it, used to burn holes in pistons ( direct injection ) . so obviuosly there is a dangerous point for those with direct inj . so those with ye olde pre-cos diesels have a bigger scope to work with ............
when i say
fuel cooling its only to 30 - 25 deg celsius , not much less...as long as its constant
324614
Reply By: fisho64 - Wednesday, Sep 10, 2008 at 01:43
while with air (or gases/vapours) it becomes denser with cooler temps, this is not really the case with liquids. Try it out by getting 2 plastic coke bottles, fill one with air and one full with
water. Put them in the fridge and see which one sucks down and which doesnt. Take it further and cool the
water to the point that it changes state and see what happens-the "exploding can phenomenom".
324619
Follow Up By: robak (QLD) - Wednesday, Sep 10, 2008 at 10:11
I'll second that. Reducing the temperature of air reduces it's volume by a lot, therefore getting more oxygen into your engine. The change in volume of cooled liquids is insignificant.
591741
Reply By: Member No 1- Wednesday, Sep 10, 2008 at 07:18
thats why they fit intercoolers to turbo'd and supercharged engines...and even
water injection
324627
Reply By: Lex M - Wednesday, Sep 10, 2008 at 09:39
Believe the electronically controlled diesels have a
fuel temperature sensor and compensate for the
fuel temperature.
324640
Reply By: Member - Hughesy (NSW) - Wednesday, Sep 10, 2008 at 10:21
with most new electronic diesels having oxygen sensors in the exhaust, I would presume that they are constantly monitoring the fuel/air ratio and hence the very slight gain you might get from having denser
fuel is already being compensated for by the computer ie. its putting the max
fuel in to gain the most effienct combustion. Cooling the
fuel will achieve zilch!!
if its an older mechanical pump then it may be of benefit but I doubt you'd notice any real world difference.
the rotary pumps on the cruiser 1HZ actually return approx 4/5 of the
fuel they pump, back to the
tank. This is their way of cooling themselves (and lubricating). This is also why you don't run around on near empty tanks all the time during summer as the small volume of
fuel will get hotter and hotter as it circulates. Switching between tanks (to allow the
fuel to cool) is a good idea if you have to run at low
fuel levels.
first thing I would do is measure the temp of the
fuel entering your pump. you might find that its not much above ambient temp and hence you'll get very little cooling effect anyway.
let us know what you do anyway.
324643
Reply By: Honky - Wednesday, Sep 10, 2008 at 10:41
Don't the old diesel
fuel pumps have a return line that would circulate cool
fuel from the
tank?
Honky
324646
Reply By: awill4x4 - Wednesday, Sep 10, 2008 at 22:58
Methanol
fuel (100%) used in racing cars is so cold it cools the intake air charge to the extent that intercooling isn't required on turbo/supercharged engines.
Regards Andrew.
324728
