vhf radios: any use in the bush
Submitted: Thursday, Sep 11, 2008 at 22:09
ThreadID: 61587 Views:4638 Replies:7 FollowUps:1
Going outback: camerons corner, Diamintina NP, Alice, Strexlecki etc.
SatNav fell through, will be carrying EPIRB, is ther any point in carrying the old marine VHF set that I have, purely for dire emergency use? I seem to remember that they will bounce off the inosphere and get distance reception that way?
Tx in advance for advice.
Reply By: SteveL - Thursday, Sep 11, 2008 at 22:30
VHF frequencies do not bounce off the ionosphere.HF frequencies are the ones you were thinking of.Your radio will be pretty much useless inland.
AnswerID: 324864
Reply By: Member - Mick O (VIC) - Thursday, Sep 11, 2008 at 22:34
Sounds like a fantastic trip Nigel and one you'll enjoy. Great country. Have sent you a mm regarding your query.
Cheers. Mick.
AnswerID: 324866
Reply By: Member - Olcoolone (S.A) The O - Thursday, Sep 11, 2008 at 22:35
If you are going to take a VHF marine radio with you you might want to consider a CDMA phone and a old 27Mhz AM CB radio as well, all three would be as good as each other.
In an emergency you would have more luck sending smoke signals.
Sure VHF has got very good range, in some instances up to 150 kilometers or more.
VHF marine radio may be good along the coastal areas but inland no.
UHF radio and an EPIRB (PLB) would be minimum requirements.
You might want to look at hiring a sat phone or HF radio, sat phones are easier to use then HF radio.
What do you mean SatNav fell through?
AnswerID: 324867
Reply By: OzTroopy - Friday, Sep 12, 2008 at 00:38
If you have a distress beacon ... thats a hell of a start.
http://www.flyingdoctor.net/HF-Radio---Communications.html
http://www.vks737.on.net/pdfs/DOC%2006.pdf
A UHF will let you contact someone in very close proximity unless there is repeater towers in the vicinity extending the range.
A 27mhz AM / SSB ( not AM only ) will give you ... your ionosphere bouncing capability. Trick will be - getting anybody but Indonesian fishing boats to hear you these days and where to store the 9' antennae needed to get a best result.
Bris to Melb / Darwin to Bris, / T'ville to Perth / was all typical of distances regularly achieved back in the heady days of 27mhz SSB comms. Didnt matter who you spoke to in an emergency ... they could normally talk to someone close to you. Heard many NT / Kimberly problems sorted by relayed messages via Tassie / Qld / WA and back to Darwin on the "emergency" channel.
Was a good cheap backup system for travel. In the right weather conditions even AM could achieve Bris to Melb ... but rare.
AnswerID: 324883
Reply By: Willem - Friday, Sep 12, 2008 at 06:13
Your VHF radio will be good for a jack stand if you happen to need to use the jack for any reason.
UHF, NextG, Satphone, EPIRB in that order
Plenty of traffic where you are going.
AnswerID: 324884
Reply By: Member - Colin (WA) - Saturday, Sep 13, 2008 at 11:53
Is your Epirb 121 mhz ? If so this system is being switch off on 1st Feb 09 so all 121 epirb's will be useless . The 406 mhz will be the standard frequency from now on.
Col
AnswerID: 325064
Follow Up By: Member - Mike DID - Saturday, Sep 13, 2008 at 23:52
Not useless - just limited.
All comercial jets still monitor 121.5 and will report EPIRBs.
FollowupID: 592276
Reply By: Member - nigel P (NSW) - Saturday, Sep 13, 2008 at 20:39
TX all. I'll save the space. The loan satnav fell thru and the rental for the satnav didn't seem worthwhile for thr short times off the traffickrd roads. FYI I carry lots of self help recovery gera, but ther is a limit to the budget!
AnswerID: 325130
