My Blog is not showing
Submitted: Friday, Sep 12, 2008 at 18:10
Member - Prickle (SA)
I have just loaded a blog and it is in my profile, but it has not shown in the general blog area.
Have I done something wrong or do they take a while to load up?
Some time ago, I recall see the option to have
blogs shown to the general
forum or just in the blog area, did not see this option this time.
Reply By: Member - Tony B (QLD) - Friday, Sep 12, 2008 at 18:32
Still we can read your blog from the shortcut. Regards Tony
324976
Follow Up By: Member - Prickle (SA) - Friday, Sep 12, 2008 at 19:43
Tony,
Thanks for your response.
Not sure where you are talking about.
When you click on
BLOGS, at the top, does not show for me as the last blog posted nor is it listed in any of the
blogs there.
Ta
592096
Reply By: equinox - Friday, Sep 12, 2008 at 19:49
I think the
blogs are sorted by the date you enter. Yours from 15 August then will come after all the ones that have a date later than that.
324986
Follow Up By: Member - Prickle (SA) - Friday, Sep 12, 2008 at 19:57
Thanks Equinox, after a bit of looking around I found, guess it is just a matter of familiarity.
First blog.
Thanks again.
592100
Follow Up By: ExplorOz - David & Michelle - Friday, Sep 12, 2008 at 20:22
Russ,
We are actually making a number of modifications to
blogs in the next few days and this exact issue is going to be addressed. Currently the
blogs are shown as mentioned based on the date you enter which is how it should be however we will be tracking the updated date and showing it on the system based on this and not the entry date. I hope this makes sense and it will be installed next week. It will mean regardless of the entry date a new item will be shown in the
forum and in the tables on the blog pages.
Good question.
592106
Follow Up By: Member - Prickle (SA) - Friday, Sep 12, 2008 at 20:28
Thanks David,
The search option was on my mind and it would have only been a matter of time before I asked this one too.
I take it that you mean if I wanted to search on Ottway Ranges in the
Blogs area, that you will be providing for this?
I gather that it can only be done currently by checking entries for each date on the calander?
592110
Follow Up By: ExplorOz - David & Michelle - Friday, Sep 12, 2008 at 20:36
Russ,
Search works already try this link to see
Blogs on
Simpson Desert or
Birdsville.
I will be added a search option on the
Blogs pages but at the moment it is in
Site Search.
592112
Reply By: Member - Prickle (SA) - Friday, Sep 12, 2008 at 20:11
Nother question.
I have now had a bit of a look around.
When checking the
Camping Blog, says there are 36 entries. There are 10 on the page that comes up, I cannot see a "next page" etc.
How do I access the rest?
324993
Follow Up By: ExplorOz - David & Michelle - Friday, Sep 12, 2008 at 20:25
At the moment you need to use the calendar control to navigate around this is also in the updates target as it is not as easy as we would like. So thanks for this one also it will be adjusted next week.
One thing that we have done in the last few days is add
blogs to the
site search so you can do a search using the Search option in the menu or the link and find any blog based on your search paramaters.
David
592108
Follow Up By: Member - Prickle (SA) - Friday, Sep 12, 2008 at 21:04
Thanks again David.
I am obviously under utilising this site.
Learning all the time.
RB
592117
