1HD FT alternator charging
Submitted: Saturday, Sep 13, 2008 at 21:03
ThreadID: 61639 Views:9401 Replies:5 FollowUps:6
Hi all. Can anybody help me with my alternator problem please? I have a 96 model 80 series with the above engine, auto trans. Every morning I start it the alternator has only 12.3 volts at the alternator. Exactly 2 minutes later the charge rate jumps up to 14.1 volts like someboy flicked a switch.
The alternator was over hauled by an auto elec. Next day exactly the same. They had another look at it the next day, same thing. They reckon new diode pack because it had a crook diode. The second time a new reg. They have had another look at it and they reckon it was a bad plug connection at the excitation wiring plug. Guess what. Next day still the same.
Me thinking three times your out.
Its been doing it for 9 months. Once it warms up it fine until you shut it down for a few hours.
Its running a dual battery system with an ABR isolator. No other mods to the wiring.
Does anybody have any suggestions?
Scott
Reply By: Member - Barnray (NSW) - Saturday, Sep 13, 2008 at 21:12
If it ain't broke !!!! The reg is probably set that way and if the charge is good why tear your hair out.Barnray
AnswerID: 325137
Reply By: Member - Graham H (QLD) - Saturday, Sep 13, 2008 at 21:14
Well dont know about yours but 1HD-FTE is exactly the same and looking in the manual it says its because the battery supplys current to the glowplugs for 120secs.
When I leave home the battery gauge shows low till I reach the corner of my street and then it pops up to full charge. Ask Toyota if that is correct
AnswerID: 325138
Follow Up By: Member - 120scruiser (NSW) - Saturday, Sep 13, 2008 at 21:22
Good theory but no glow plugs in mine. They do have a pre heat element in the air intake so I will put the volt meter on that when I start it on Monday morning and see if that has power for 2 minutes. It is something for me to check.
Thanks for the suggestion.
Scott
FollowupID: 592239
Follow Up By: Member - Phil G (SA) - Sunday, Sep 14, 2008 at 18:40
Scott,
Its the preheat element. My 1HD-FTE does it too.
FollowupID: 592378
Reply By: TD100 - Saturday, Sep 13, 2008 at 21:18
120,
has it always done that? the 100 series does not charge immediately after start up, it kicks in after about 1 minute of running, a relay clunks in and it starts charging. thats when its cold but when warm it charges almost straight away after starting. i will ring my mate and see if his 1HD-FT 80 series does that also. cheers Paul
AnswerID: 325140
Follow Up By: Member - 120scruiser (NSW) - Saturday, Sep 13, 2008 at 21:21
I have only had it since September last year and it has always done it. When you start it cold the lights are dull and the wipers hardly work and as soon as the alternator clicks in everything brightens up.
It might be how they are.
I have ordered a manual so I will read up on it when that turns up.
FollowupID: 592238
Follow Up By: TD100 - Saturday, Sep 13, 2008 at 21:24
Yep the 80s must be the same, he is not home but going on what others have said the 100s and 80s are like that.
FollowupID: 592240
Follow Up By: furph - Sunday, Sep 14, 2008 at 07:13
Exactly the same in the 1hz/75 series.
The glowplugs must really take a whack out of the system. Two mins. later a click from the relay (behind the glove box) and the voltage needle jumps up.
And as other reports, only when the engine is cold (first start of the day)
furph
FollowupID: 592294
Follow Up By: Oldsquizzy (Kununurra) - Sunday, Sep 14, 2008 at 09:58
Tis normal, 61 series with the 12ht do the same second or third corner up it goes.
FollowupID: 592320
Reply By: autosparky - Sunday, Sep 14, 2008 at 14:18
it is normal the glow systems can eat up to 80 amps
AnswerID: 325239
Reply By: Member - 120scruiser (NSW) - Sunday, Sep 14, 2008 at 21:14
Thanks all.
I will stop worrying.
AnswerID: 325309
