Bike carrier
Submitted: Friday, Jul 25, 2003 at 08:45
Savvas
Does anyone know of a bike carrier that attaches to a rear mounted spare tyre such as that on a Jackaroo? I want to get one that can hold two bikes.
I saw one years ago on a Jackaroo that bolted to the centre of the spare tyre carrier. However, I haven't seen one since and just cannot remember a brand on it.
Reply By: pathfinder - Friday, Jul 25, 2003 at 08:53
would suggest that this would be ill-advised unless spare is mounted to a swingaway carrier. If spare is mounted to door, putting further weight on it may result in a sagging door or even broken hinges...
25880
Follow Up By: Savvas - Friday, Jul 25, 2003 at 11:21
I must admit, that did cross my mind.
You've convinced me, I think I'll go for a swagman carrier that mounts in the towbar receiver.
Thanks!
17577
Reply By: Graham - Friday, Jul 25, 2003 at 18:47
Haymen Reece do a bike carrier which fits into the towbar receiver and has an extended arm so to clear the spare.
25920
Reply By: Paulb - Friday, Jul 25, 2003 at 21:17
The Thule SPARE ME fits 2 bikes on the spare wheel and is safe (MAX 30kg of bikes). It is not designed for off road use however for anything else it works perfectly.......have a look
www.thuleracks.com/thule/product.asp?dept_id=8&sku=943
If you want a hitch mount carrier I would look at the Thule ones as
well. Look here
www.thuleracks.com/thule/product.asp?dept_id=8&sku=935
For info contact Thule Australia at www.thule.com.au......
Cheers....Paul.
25935
