nissan turbo ebay
Submitted: Tuesday, Sep 16, 2008 at 20:07
ThreadID: 61733 Views:1875 Replies:2 FollowUps:0
i see there is a turbo off a nissan 4.2 on ebay
http://cgi.ebay.com.au/2005-Nissan-Patrol-GU-diesel-turbo-turbocharger_W0QQitemZ200253045018QQihZ010QQcategoryZ30862QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
can anyone tell me if this will go onto a naturally aspirated 4.2. i am thinking of turboing my ute. ( it looks brand new -or not used much ) thanks.
Reply By: Member - Matthew C - Tuesday, Sep 16, 2008 at 21:12
You will need to get a manifold to suit,get a factory turbo setup from the wreckers complete instead of buying bits all over the place.
MAtt
AnswerID: 325629
Reply By: Member - Christopher P (NSW) - Wednesday, Sep 17, 2008 at 21:18
Also ask to see it as most often then not they need to be rebuilt, as i have worked in wrecking yards and panel beaters for 15 years, i can tell you a good clean up on parts will make them look almost /if not brand new.
To tes a turbo you need to wiggle the compressor and turbine up and down and sideways, too much up and down turbo needs a rebuild!!! Big dollars that, toomuch siideways movement same deal, don't get me wrong, i could be wrong, best to check with your mechanic and a turbo specialist!!
AnswerID: 325800
