Anyone still having Server Related Problems?
Submitted: Tuesday, Sep 16, 2008 at 21:05
ThreadID: 61736 Views:2886 Replies:10 FollowUps:29
Evening All,
after David restarted the server the other night all came good, but tonight it will open up a thread OK,back out of it to open another but it wont,the little white hand wont appear to click on what you want to open,click in mid flight and wait about 10 seconds and its all good.operates the once again and nothing again.it is only this site that is doing it as i have checked some others.it is quite annoying these little peculiaritys that we encounter on here! cheers Paul
Reply By: Member - John (Vic) - Tuesday, Sep 16, 2008 at 21:26
Yes!! me too, I was begining to think it was a problem with my machine.
AnswerID: 325634
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 21:31
Please tell me browser type and if you can let me know how to duplicate that would be great?
David
FollowupID: 592688
Follow Up By: Member - John (Vic) - Tuesday, Sep 16, 2008 at 21:37
IE 7.
Duplicate??? Not sure it just seems to hang and as said above it requires a click on a blank area and it seems to think about it for about 10 seconds then works as it should.
FollowupID: 592693
Follow Up By: Member - John (Vic) - Tuesday, Sep 16, 2008 at 21:39
Sorry should have said IE7 on XP Professional.
FollowupID: 592695
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:30
See how you go now John I believe I have found it and solved it.
FollowupID: 592717
Follow Up By: Member - John (Vic) - Tuesday, Sep 16, 2008 at 23:33
Thanks David seems all good again :-)
FollowupID: 592733
Reply By: Member - Nev (TAS) - Tuesday, Sep 16, 2008 at 21:29
Hi Paul,
Me too!
AnswerID: 325635
David
FollowupID: 592689
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:31
Should be fixed now (I hope).
FollowupID: 592719
Reply By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 21:29
What browser are you using for this issue? I think Damian has seen something similar with IE7 but we were not 100% sure. If it is I know where to look.
You may see strange issues every now and then becuase I install new and updated tools and components almost every day and most of the time they work well and others sometimes cause a few teething problems.
David
AnswerID: 325636
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 21:30
Also please tell me how to duplicate the problem if you can duplicate it.
FollowupID: 592686
Follow Up By: Member - Borgy.. (SA) - Tuesday, Sep 16, 2008 at 21:39
David
When you open a thread and click back after you finish with the thread it returns back ok , but then sort of freezes for about 15 - 20 seconds..
Cheers......Borgy
FollowupID: 592694
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 21:48
The back you are refering to is it Browser back or Back to Index button on the page? Thanks.
FollowupID: 592699
Follow Up By: Member - Borgy.. (SA) - Tuesday, Sep 16, 2008 at 21:53
Browser back for me Dave, i haven't even thought about trying the back to index button, i'll give it a try and let you know what happens
Cheers......Borgy
FollowupID: 592703
Follow Up By: Member - Borgy.. (SA) - Tuesday, Sep 16, 2008 at 21:55
Tried the back to index Dave, still the same .....
Cheers......Borgy
FollowupID: 592704
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:29
Try it now Borgy - I belive I have found and fixed the error. At least I hope I have.
FollowupID: 592716
Follow Up By: Member - Borgy.. (SA) - Tuesday, Sep 16, 2008 at 22:38
Perfect David, thanks , your a bloody genius...lol...
Cheers......Borgy
FollowupID: 592723
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:40
Thanks but I am also sorry it was broken.
FollowupID: 592724
Reply By: Member - extfilm (NSW) - Tuesday, Sep 16, 2008 at 21:32
good...... I thought that I too had a prob..... it is kinda freezing for a little then let u in......... Almost like my nissan..... it misses a beat every time u open it up.
AnswerID: 325637
FollowupID: 592718
Reply By: Member - Borgy.. (SA) - Tuesday, Sep 16, 2008 at 21:34
G'day TD
Im having the same problem as well, started doing it last night for me, like someone above said i also thought it might be my computer, but its only doing it on EO...
Cheers.....Borgy
AnswerID: 325638
Follow Up By: Member - Borgy.. (SA) - Tuesday, Sep 16, 2008 at 21:36
Forgot to mention im also using IE 7 with Vista HP
FollowupID: 592692
Follow Up By: Member - Mark G (NSW) - Tuesday, Sep 16, 2008 at 21:43
hi all
i'm using firefox on vista, all very good here,cheers.
FollowupID: 592697
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 21:46
Yes Mark Firefox does not have these issues - this is now my default browser alas I need to make IE work so will have to try to find it. I did install a new Tooltip system yesterday and I suspect it is related. If you have not seen it try hovering over this Places or Shop or even Waeco.
FollowupID: 592698
Follow Up By: Member - Nev (TAS) - Tuesday, Sep 16, 2008 at 21:50
I can get it by just refreshing the Forum pages. Mostly it takes a time (up to 5 seconds) to do a refresh and chews up 100% CPU in IExplore. Sometimes (maybe one out of ten) it works Ok and sometimes I get a server error. The server error hasn't happened for over 30 minutes or so now. I cannot remember which it was but I have had either a Shockwave or a Flash upgrade this week. Can't remember which. Run XPsp3 with IE7. Shockwave version 11 and Flash version 9.0.124.0
All Microsoft updates current. Am running Symantec Antivirus v 10.1.6.6000
FollowupID: 592701
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:41
Nev - It is fixed now please try again and let me know.
FollowupID: 592725
Follow Up By: Member - Nev (TAS) - Wednesday, Sep 17, 2008 at 08:30
Yup all looks good now.
Many thanks
Nev
FollowupID: 592750
Reply By: Oldsquizzy (Kununurra) - Tuesday, Sep 16, 2008 at 21:36
interent explorer 7. same thing for a couple of days. When loading hangs and when returning to forum page hangs again.
Works fine every where else is just this page.
AnswerID: 325639
FollowupID: 592720
Reply By: Kim and Damn Dog - Tuesday, Sep 16, 2008 at 21:57
This is not an Exporoz problem. We've being having the same issues at work.
Kim
AnswerID: 325645
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:04
Kim,
It is a problem with IE 7 and it is realted to Javascript execution - I wonder if there has been a security update or windows update in the last 2 days that may have caused this. I will investigate a little furthur - I have seen some new updates in the last day or two.
I can see the error occuring it is related to latency of the ad loaded at the top of the screen. I will do a little more digging and see if I can find something.
let em know if you sort it at work also.
FollowupID: 592711
Follow Up By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:32
Kim,
In this case I think it was my problem and I have now resolved it (I hope).
FollowupID: 592721
Follow Up By: Shaker - Wednesday, Sep 17, 2008 at 11:10
This is the only website that gave me the momentary 'freezing' problem.
All OK now though!
FollowupID: 592769
Reply By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:08
OK I can now see it and have worked out where it is but the why is still baffling it is new last two days or so.
It is a problem with IE 7 and it is realted to Javascript execution - I wonder if there has been a security update or windows update in the last 2 days that may have caused this. I will investigate a little furthur - I have seen some new updates in the last day or two. As mentioned it only effects IE7 (so far) as my IE6, Opera and Firefox systems do not have this problem at all.
Leave it with me and I will get some information and feedback when I know more.
(I know know why I upgrade to Firefox as the default but IE 7 is still the most used browser so I will certainly be fixing this with priority - however I suspect the issue has been injected by Microsoft during an update)
AnswerID: 325648
Follow Up By: David A A - Tuesday, Sep 16, 2008 at 22:24
Hi David
I have just been having this problem using IE6 on XP
regards
David
FollowupID: 592715
David - I think I have found and fixed it let me know.
FollowupID: 592722
Reply By: ExplorOz - David & Michelle - Tuesday, Sep 16, 2008 at 22:28
OK found it and fixed it I hope - please do a refresh and then try it all again and let me know. There was a function in the new tooltip code that was running a large JS replacement function as the page loaded - the forum index page has a large number of divs and the replacer was working through all of these.
IE seems to be the only browser that did not like this function - I do not use it so have disabled it in the master library so hopefully that should be problem solved.
Let me know?
AnswerID: 325655
Follow Up By: TD100 - Tuesday, Sep 16, 2008 at 22:50
Hi Folks- Yep all good now, it was driving me nuts! hahaha i am running XP and IE6, tried 7 and some of the firefoxes but dumped them in favour of these 2. gave me more trouble than they were worth. thanks again Paul
FollowupID: 592727
Reply By: Maîneÿ (wa) - Wednesday, Sep 17, 2008 at 11:57
David,
I still have the same hassle as reported earlier to Damian, with all words, including the round 'forum logo' and the 'font' and 'print logoes' all being moved across about 1/3 to the right of the boxed area, leaving an empty space in the first 1/3 area, and it's moved so it's covering the 'advertising' and pictures on the right perimeter and out onto the blue extreme border arera on the right side.
This is only happening when I look at the "original" first post.
all replies are correctly situated with-in the boxed area.
Using FireFox & Win MCE.
(I won't be able to answer questions till I get back to WA)
Mainey . . .
AnswerID: 325707
