Toyota diffs
Submitted: Tuesday, Sep 16, 2008 at 22:11
Charlidees
Hi just wondering if anyone can help me. I need to replace the rear diff centre in my 98 troopy and have been offered an 80 series to put in. Can anyone tell me if the ratio is the same and are the 80's an lsd too. Any other info would be greatly appreciated thanks
Reply By: BarryMcKenzie - Tuesday, Sep 16, 2008 at 23:32
Have no idea if diff ratios are the same but my 94 80 series has a limited slip in it, (not that you would know)
325663
Reply By: Krakka - Wednesday, Sep 17, 2008 at 05:13
Can't answer your question, BUT if I had to replace
mine it would be with a Lokka diff lock.
Regards Krakka
325672
Reply By: Top End Explorer Tours - Wednesday, Sep 17, 2008 at 07:44
Count the teeth on both crown
wheels and pinions, if they are the same, then they are the same.
Cheers Steve.
325680
Reply By: Member - Matt M (ACT) - Wednesday, Sep 17, 2008 at 08:42
Yep, 80 series is an LSD in the rear (after a fashion).
Almost certain that the ratios are the same. The 80 series ratio is 4.111:1 (from the manual) and I am pretty sure that the 70 series is the same except the new ones which are 3.909:1 I think.
Look
here for a good sheet on diff ratios.
Matt (who would also be thinking of some kind of locker)
325683
