Airsafe Hitch
Submitted: Wednesday, Sep 17, 2008 at 07:20
Member - Rod N (QLD)
Has anyone used an Airsafe hitch, without or with load levelers. It has an airbag incorporated to take out the shock loads when towing.
Airsafe Hitch
Thanks Rod
Reply By: Member - Tessa (NSW) - Wednesday, Sep 17, 2008 at 09:57
Rod
Interesting concept. I've never seen it before. I guess what they call tongue weight (tg) is what we call ball weight. They are talking some pretty heavy loads to be placed on what seems to be a standard towball. The class 5 , which looks to be the biggest one using a standard ball converts to a ball weight of 635kg and a gross towing weight of 6350kg. It's also interesting that they lower their approved ball weight substantially when used in conjunction with a weight distribution bracket (apparently the same thing as our WDH).
tessa
325694
Reply By: DCTriton - Wednesday, Sep 17, 2008 at 19:02
Have seen a black hummer and a white 200series around here, both with 'airsafe' and a 95mm Bartlett Ball system - good for approx 6t from memory...
325759
