attaching an outboard to a Jayco Outback Dove
Submitted: Wednesday, Sep 17, 2008 at 19:26
johnnyD
Can anyone advise on the best way to secure a small 2hp outboard to a Jayco Dove outback?
Reply By: sjp - Wednesday, Sep 17, 2008 at 19:39
we extended the rear tyre carrier and put a couple brackets there to hold the motor horizontal
325778
Reply By: Hairy (NT) - Wednesday, Sep 17, 2008 at 19:46
Gday,
Id make a mount on the "a" frame.
But are you sure It will float????
325781
Follow Up By: Peter 2 - Wednesday, Sep 17, 2008 at 19:56
My thoughts exactly, will need plenty of silicon to seal it all up, might need additional floatation as
592827
Follow Up By: Louie the fly (SA) - Wednesday, Sep 17, 2008 at 20:03
Someone was bound to say that. Very predictable. Funny, but predictable. LOL
592828
Follow Up By: Member - Paul W (VIC) - Wednesday, Sep 17, 2008 at 20:20
Yeh but you cant buy entertainment like that though can U?
592832
Reply By: Member - Norm C (QLD) - Wednesday, Sep 17, 2008 at 19:52
This bracket looks the goods. I hope it is good as I have one on my new caravan (picked up yesterday), but have not used it yet. Might be overkill for such a small motor, but I guess you need a solution and this seems to be a good one.
Slip n Easy boat bracket
325783
Follow Up By: Member - Beatit (QLD) - Thursday, Sep 18, 2008 at 08:08
Hi Norm,
Congratulations on you new van - when is the first trip?
Kind regards
Theo
592894
Follow Up By: Member - Norm C (QLD) - Thursday, Sep 18, 2008 at 08:25
Couple of short 'shake down cruises' over the next couple of months, including
Canberra in Nov.
Late Jan we plan on hitting the road for at least 12 months - probably much longer.
Lots of setting up to do on the vehicle before that.
Norm C
592897
Follow Up By: Member - Beatit (QLD) - Thursday, Sep 18, 2008 at 08:31
Hope it all goes
well for you and all the best for your travel - sound like a great plan.
Kind regards
Theo
592899
Reply By: johnnyD - Wednesday, Sep 17, 2008 at 21:02
Thanks for the replies. Anyone else got any photos of their outboard mounts.
(and yes 2 hp is enough to push a Jayco Dove across the murray)
325795
Reply By: johnnyD - Wednesday, Sep 17, 2008 at 21:03
325796
Follow Up By: Member - Fred G (NSW) - Thursday, Sep 18, 2008 at 17:57
johnnyD..... I have a mount for my 2hp johnson on the A frame. Just a post with a transom plate on top, clamped onto A frame with an extra jockey wheel clamp. Very simple. Have travelled many
miles with this. I put a cover on it when travelling.
Cheers mate.Image Could Not Be Found
Fred.
592969
Reply By: johnnyD - Thursday, Sep 18, 2008 at 18:04
Thanks that looks good. Is the post just welded? Strong enough?
JohnnyD
325931
Follow Up By: Member - Fred G (NSW) - Thursday, Sep 18, 2008 at 18:42
The top of the post has a piece of angle iron welded onto it and a piece of timber is bolted to the angle iron to replicate a transom for securing the motor. I then tightly secure the mounting screws of the motor and lock them together with a padlock. As I said, I have travelled many
miles and all good. Very cheap to make mate.
Fred.
592984
Follow Up By: Hairy (NT) - Thursday, Sep 18, 2008 at 23:48
Gday,
I hope this doesnt sound critical of your job Fred, cause it isnt meant to.
But that set up wont last with vibrations or off road.
Im not sure what your after realy.....you need nore gussets but be careful not to change the structure of your a frame at the same time.
How
well can you weld????
593082
