Hot h2o systems
Submitted: Thursday, Sep 18, 2008 at 23:23
ThreadID: 61817 Views:3526 Replies:8 FollowUps:2
I have a camper trailer (Cub Spacematic) with a 3 Lt Patrol as a tow. I am looking at a hot water system for a shower set up. Don't like the solar bag thing much. Any experiences and suggestions would be appreciated. Regards Quentin
Reply By: joeblogs - Friday, Sep 19, 2008 at 06:53
The easiest way is to boil a billy of water and add it to a bucket of water drop in a $20 dollar 12 volt shower. This system uses much less water than other methods, as you can quickly wet yourself turn off the water then lather up with soap turn water back on and rinse.My wife and myself can both have a good shower with about eight litres of water.WE used to use a 20 litre drum with a tyre valve fitted on the cap and a hose connected to the bottom this then went to a shower rose. A compressor was then connected and turned on. This system gave fantastic water pressure but was also a great way to waste water as we would use almost all the water in the drum.
We used a black water container and it was left out in the sun for the day to heat (sometimes to hot)
AnswerID: 326046
Reply By: Sir Kev & Darkie - Friday, Sep 19, 2008 at 06:55
Get a Coleman Hot Water system.
Very simple to use with a variety of uses.
Cheers Kev
Russell Coight:
AnswerID: 326047
Reply By: Member Brian (Gold Coast) - Friday, Sep 19, 2008 at 07:34
The Boil-The-Billy/12volt-$20-pump system is the cheapest.... but the Coleman Hot Water system is the most versatile and easiest to use!
Brian
AnswerID: 326053
Reply By: Member - Reiner G (QLD) 4124 - Friday, Sep 19, 2008 at 08:28
It's camping remember........boil the billy and hang the canvas bag in the tree or of your car.......no 12 volt problems or running out of Gas.
Reiner
AnswerID: 326064
Reply By: bundyluva - Friday, Sep 19, 2008 at 09:06
You can't go past a Coleman Hot Water System. They are a touch of luxury when out camping and very useful when you have two young boys running around getting dirty!!!
I also read a forum on here where people suggested using a pressure garden sprayer - heat your water up and put it into sprayer for a wash down. I thought the sprayer idea would be worth a try if we didn't have the Coleman system.
AnswerID: 326072
Reply By: Member - Phil G (SA) - Friday, Sep 19, 2008 at 09:42
If you have heaps of water, go for the fancy showers.
If you want to use 4-8 litres per shower, use the $20 12V and a 8 litre crockpot. Heat up on fire or stove.
If you want to use 2 litres per shower (and take twice as long to shower), use a 4l Hills garden sprayer with cut down wand - billy of hot with 2 billies of cold usually does it.
AnswerID: 326076
Reply By: QS - Friday, Sep 19, 2008 at 10:26
Thank you all for your responses. I will have a look at the Coleman. I have talked to the people at Glind and received the normal stuff. We have used the garden sprayer when we lived aboard our yacht(recently sold). We painted the outside black and lashed it on deck and had a fairly efficient solar pressure hot water system but probably would have problems in a dusty environment. Done the canvas bucket for many years also but need just that bit extra in advancing years. Thanks again and regards to you all. Quentin
AnswerID: 326085
Reply By: Member - bungarra (WA) - Friday, Sep 19, 2008 at 18:16
We have a Glind and have used it successfully for years
it doesnt matter a damn what system you use to shower with..it is not the system that wastes the water ...it is the user!.........be it Coleman, Glind or the hot billy!...we have susseccfuuly had a very refreshing sponge bath in an ice cream container half full when water is scarse
We use the rose to wet ourselves...turn it off...lather up and then turn it on to rinse........doesnt need to use any more or less than the other posts / systems have suggested
at least the Glind sits under the bonnet and takes no room from elswhere and utilises the engine as a heat and power source.....does the Coleman do this?... I dont believe so
VKS 1341
AnswerID: 326156
Follow Up By: Crackles - Friday, Sep 19, 2008 at 21:58
Having owned a Glind for 20 years I have to disagree somewhat on water use. Each time a Glind system is turned off at the rose the water in the hose goes cold while that in the heat exchanger near boils meaning when you turn it back on you must run it for however long your hose is before safely getting under again. As the engine runs at idle, water flow is basically set to maintain the temp so can't be backed off much without getting too hot.
Where we did find it to be great however was you could shower 20 people one after the other. Have pulled it off the car now opting for a simple canvas shower bag instead.
PS: Not a fan of the Coleman's either. (but that's another story)
Cheers Craig............
FollowupID: 593223
Follow Up By: Member - bungarra (WA) - Friday, Sep 19, 2008 at 22:32
Crackles...your comments are spot on re the heat generated when not circulating BUT why waste thiswater whilst waiting for it to reach usable temperature again?...
all we do is to recycle it back into the bucket until the temperature is acceptable then use it............if the body of water gets too hot we just turn the engine off and run the pump....still doesnt use more water
I stick by my original comments...when the shower rose is running somebodys is under it (two if you get lucky :))
cheers bungarra
VKS 1341
FollowupID: 593230
