Using air bags and carvan load compenstion bars with rear brake compensation val
Submitted: Friday, Sep 19, 2008 at 12:03
Member - Oldplodder (QLD)
So if I have a bit of load in the rear, and maybe the trailer ball load as
well, and pump up the air bags to level the
suspension, does this nullify the brake compensating valve?
OK, things you think about when travelling.
On the highway on the way back from
Darwin, when I had to do a brake and swerve to miss a goana, I started thinking about the braking on the old paj.
It doesn't have ABS, and just a brake compensating valve in the rear. You know the thing, a spring from the compensating valve in the rear brake system to the axle, so if the car is loaded, it gives a bit more braking on the rear, or proportionally less braking to the front.
Suppose the same would apply with a caravan and a load distribution hitch?
Is it worth worrying about and can you do anything about it?
Reply By: Wizard1 - Friday, Sep 19, 2008 at 12:38
Put some music on and try and thik about something else.
326107
Follow Up By: Member - Oldplodder (QLD) - Friday, Sep 19, 2008 at 14:08
Yeah, you are right.
The next beer is more critical :o)
593147
Reply By: Member - Rodney B- Friday, Sep 19, 2008 at 15:22
The answer is yes it does reduce the compensation but only marginally so have another beer and continue driving. Suggest it's not a good idea so swerve to miss goannas or anything especially with a van or trailer on the back. Brake hard but stay in a straight line and it may prevent you from looking like road kill.
God I wish I was on the road at the moment, next month the high country Yee haaa.
326127
Follow Up By: Member - Oldplodder (QLD) - Friday, Sep 19, 2008 at 15:53
Was almost going to run over the lizard.
Had already wiped out a stupid lamb on the trip and missed a couple of wallabies.
Semi was coming the other way, and I decided that was room to go around the goana without scaring the truck driver.
Apologised to the truckie on the CB, but he had seen the goana too, so knew what I was up to.
Glad I have the clearance of the 4wd and 4wd trailer to straddle some of the road kill on the road. Could be a bit dicey with a standard car missing road kill in the middle of the lane, and having traffic coming the other way.
593158
Reply By: Nomadic Navara - Friday, Sep 19, 2008 at 21:18
John C
Quote "It doesn't have ABS, and just a brake compensating valve in the rear. You know the thing, a spring from the compensating valve in the rear brake system to the axle, so if the car is loaded, it gives a bit more braking on the rear, or proportionally less braking to the front."
If you trim the vehicle stance by using air bags (instead of WDH) you raise the rear
suspension and th brake compensating reduces the braking effort on the rear
wheels without putting weight back on the front
wheels t0o improve the braking performance of those front
wheels.
If you trim the vehicle by using WDH then you both take weight from the rear
wheels as the rising
suspension removes the braking effort from the rear
wheels. At the same time you transfer the weight from the rear
wheels to the front ones and make their braking dynamics more effective.
326188
Reply By: Eric Experience - Friday, Sep 19, 2008 at 21:32
John C.
Very timely question, I am fitting air bag
suspension to my 4x4 today and was contemplating the very same question. What I decided to do was to load the vehicle with my normal travelling set up and the standard
suspension, then accurately measure the angle of the arm. When the air bags are inflated to the ride hight I wont I will then rework the linkage to the same angle. Hope this makes sense. Eric.
326190
Reply By: Bagwon - Saturday, Sep 20, 2008 at 16:27
I hope you grabed a knife and grabed yourself some lamb steaks.
326281
