Tyre pressures front and rear.
Submitted: Friday, Sep 19, 2008 at 17:29
ThreadID: 61831 Views:10962 Replies:7 FollowUps:3
The recommended tyre pressure on my 3.0DT hilux dual cab fully loaded is 170KPA (25PSI) front and 300KPA (44PSI) rear.
When travelling my load is less than max capacity and using the Pirelli 4 pound increase when hot system I find 26 front and 40 rear is about right.
Nobody here seems to differentiate between front and rear pressures. Is this something unique to dual cab utes?
Reply By: notsogreynomads - Friday, Sep 19, 2008 at 18:37
Lex, in the glove box of my GU111 Patrol the tyre placard says 40psi in the front empty and loaded and 40 to 65psi in the rear empty to loaded. hope this helps, happy trails.
AnswerID: 326161
Reply By: ross - Friday, Sep 19, 2008 at 19:01
'Nobody here seems to differentiate between front and rear pressures. Is this something unique to dual cab utes?'
Ive always had more PSI at the front where the engine weight is,but if the back is heavier ,then I would put more air in the rear.
AnswerID: 326167
Follow Up By: Lex M - Friday, Sep 19, 2008 at 19:14
Should have mentioned the unloaded recommendation is 25 front and 32 rear. When it's empty 32 in the rear is like a kangaroo on steroids. 25 all round seems about right.
FollowupID: 593183
Reply By: SheridanM - Friday, Sep 19, 2008 at 19:19
My son is a tyre fitter at beaurepairs he told me to run 40psi on front and 38psi on rear unloaded good ride and ecomony thats on a GQ Patrol
Geoff
AnswerID: 326171
Reply By: Notso - Friday, Sep 19, 2008 at 19:29
When I fitted Light Truck Bridgestone ATs to the Nissan Patrol, when I had it, the dealer recommended 28psi all round, The tyres wore evenly across the tread and lasted 90,000 ks
AnswerID: 326174
Reply By: Member - John F (NSW) - Friday, Sep 19, 2008 at 19:47
Lex, have to agree with Sheridan - we use 40/40 for highway and half loaded on the advice of our very trustworthy tyre dealer. 25 way too low for highway speed braking/steering/wear/heat etc. With a full load the rear would probably go to 50, and then check with the 4 lb rule.
Vehicle manufacturers have more concern for ride and comfort
We find the ride fine at 40/40 on our new Bridgestone 694s. Note I am referring to the SR5 with 255x70 15, the SR has, I think, different tyres and wheels, but 25 is too low for highway speeds; probably suited to rough dirt roads, but I have little experience of this.
Regards, John.
AnswerID: 326178
Follow Up By: Lex M - Friday, Sep 19, 2008 at 20:31
Mines not a SR5. When I got it second hand the previous owner had fitted 205/70R15 on aftermarket rims and ran 40 all round. Also had you beaut aftermarket high performance shocks. (Read solid). Handling was terrible, ride was rough, wet weather lethal, tyres wearing badly in center of tread. Tried various pressure settings(28/28 recommended). No better. Threw away the shocks and went back to standard, got hold of a set of standard 16 inch wheels with 205/16rc LTs and ran the factory recommended pressures (25/34 empty). Now rides better, driveable in wet, stops fine. Much safer vehicle. And as I said before the 4psi rule pretty much agrees with the factory recommendations.
Lex
FollowupID: 593200
Follow Up By: Splits - Friday, Sep 19, 2008 at 21:11
Lex
I have a Hilux 3L single cab. It still had the original factory fitted 205R16C 694s on it when I bought it. They were 8 ply 110 load rating. The handbook says they should have been 6 ply and lists the pressures as 25 front and 32 rear when empty. Fully loaded was still 25 front and up to 44 rear depending on the load.
It also lists a 205R16 Reinforced. It should be 25 both ends empty and 25 front when fully loaded and up to 34 rear.
A few weeks later I bought a second set. They were 205R16 LT Goodyears 112 load rating. The tyre service told me I should use 40 psi both ends! Assuming I should use the 205 reinforced pressures, I rang Goodyear to check. They said yes and never exceed them by more than 4 psi. While discussing the 4 psi rule, they told me all their testing had revealed there were too many variables involved for it to be reliable.
I have never had the car anywhere near fully loaded so I have used 25 front and vary the rear between 25 to 30 depending on load. That has been on both highway and off road. I drop both ends by 3 psi only on wet mountain tracks. Dry tracks are fine on highway pressures.
So far it has worked perfectly. The ride and handling is good, the wear is even and there has been no tyre damage. I have never even thought about the 4 psi rule since.
It looks like you are experiencing the same thing. In 45 years of driving, I have never owned a car that has not had stock size tyres. I have always used factory pressures with excellent results.
Brian
FollowupID: 593209
Reply By: Miss Jo - Toad Keeper (Bris) - Friday, Sep 19, 2008 at 19:58
can't rememeber what in glove box says, but tyre dealer told me with the BFG 33cmuddies, 38 front and rear. Will be transferring those muddies on a GQ, assuming will still have to run 38.
AnswerID: 326181
Reply By: T-Ribby - Saturday, Sep 20, 2008 at 11:38
Hi Lex. I use the 4psi guide, ie note the cold tyre pressures then run the vehicle for about an hour until the tyres warm up and then recheck pressures. if set correct, they should have increased by approx 4psi. pretty simple.
T.R.
AnswerID: 326251
