Electric brakes on van
Submitted: Sunday, Sep 21, 2008 at 19:42
hunter40
Took the caravan (2ton) for a trip on the weekend and did'nt think the brakes were working to
well I had the controller adjusted right up and it felt like normal driving but you could feel the brakes work if you use the manual slide any solutions?
Cheers hunter
Reply By: Member - Norm C (QLD) - Sunday, Sep 21, 2008 at 19:52
Have you checked the brake adjustment on the van itself? I'm not sure what the recommended interval for adjustment is, but I do it at least every 10,000 KM / a couple of times a year.
You need to jack the
wheels up and support it
well as you need to get underneath to make the adjustment.
Norm C
326460
Follow Up By: hunter40 - Sunday, Sep 21, 2008 at 20:21
Hi Norm,
no I have'nt checked the adjustment yet but will do, last time I towed the van it had a little more pull up although the controller was'nt quite adjust right out have only done proberly about 2000ks since buying (2nd hand) van in Jan
Cheers hunter
593570
Reply By: Member - Graham H (QLD) - Sunday, Sep 21, 2008 at 19:53
What make of controller and did u try it justwith the van brakes and not the car and what happened if you did.
They may just need adjustment
326461
Follow Up By: hunter40 - Sunday, Sep 21, 2008 at 20:29
Hi Graham,
It's a Tekonsha voyager very old one
yeh I tried with just the van brakes by using just the manual slide switch and it would pull patrol and van up no worries.
Cheers hunter
593573
Follow Up By: Member - Graham H (QLD) - Sunday, Sep 21, 2008 at 20:35
They werent the best by a long shot A good thing to do is buy the Prodigy, a far better item Derek of ABR on here sells them for a reasonable price
www.sidewinder.com.au
593577
Follow Up By: Pete Jackman (SA) - Monday, Sep 22, 2008 at 17:30
Derek also sells them on Ebay. I got one the other day - great service from Derek (as always)
Pete
593704
Reply By: Member - Charlie M (SA) - Sunday, Sep 21, 2008 at 20:01
Level setting on controller may need resetting
326465
Reply By: Ray - Monday, Sep 22, 2008 at 09:43
I live in a retirement village with a lot of
grey nomads and it would be one of if not thee biggest problems with caravans.
I have built a special set of test gear to test brakes. One thing that is not really possible is to test c'van brakes when the c'van is not moving and not possible to adjust them when the c'van is moving.
The test gear consists of a battery, a series of switches and lamps and a socket to plug the caravan inton.
Each circuit when energised gets a full 12+ volts which enables the road and c'van interior lights to be tested and by applying full 12+ volts to the brakes checks may be carried out to see if the c'van brakes fully apply. (full 12v is not always possible when using the car brakes if the car is not moving)
I also do allot of the brake adjustments on the caravans in our compound. This is done with the c'van jacked up and all the hubs removed. This way the wheel bearings can be checked, wear on the drums, shoes and magnets can be carried out and also ovality of the drums. I carry out all preliminary checking of brake adjustment with vernier callipers
326508
Follow Up By: Member - MUZBRY (VIC)(MURRAY) - Monday, Sep 22, 2008 at 10:28
Gday Ray
Your the fella that i want around when i get a caravan.
Murray
593640
Reply By: Ted G - Monday, Sep 22, 2008 at 14:37
Hunter
Sometimes there is a difference in braking depending on the weight in the caravan, such as the amount of
water in the tanks.
A good indication is when the brakes are on
park and the caravan is then loaded it can be hard to let the brakes off.
Otherwise check the terminals for corrosion as this makes a big difference.
Ted
326555
