Inflatable boats
Submitted: Monday, Sep 22, 2008 at 20:29
Corio
My son and I wish to purchase an inflatable dinghy.WE dont wish to go into the open sea however want something pretty stable and able to handle a small outboard motor.
Perhaps a length of about 12 feet to mainly go crabbing inside the protection of reefs etc and use with oars for example in Yardie
Creek.
We have obviously looked at a number of sites on the net but would appreciate some first hand knowledge.
The reason we are thinking inflatable is ease of handling and as he is disabled the ability to put him in and pullit down to the
water.
Has anyone got any ideas,please?
Reply By: donk - Monday, Sep 22, 2008 at 22:07
Corio
Inflatables have some advantages over alloy boats such as good stability when you move about in them at rest & the ablity to handle seas that would test a alloy boat of the same length (they will float when full of
water) & they will carry a bigger load as
well
They can also be carried inside the vehicle as
well & the ones with the inflatable floors are fairly compact when rolled up (no ply floor sections to stow) & are lighter in weight
The disadvantages are they have less interior space for a given length,you need to be more careful when fishing with hooks & lures,a good quality one is a lot more expensive,& they take time to set up & put away
I would not drag them along a surface with someone in it unless you were using some sort of
wheels either or you would cause some damage to the material
I have a 11 foot achillies (circa 1983) with a 8hp suzuki & the hull & motor are still going strong (a few patches though) but unless you particually want a inflatable for the reason mentioned above a alloy v nose punt or similar might be a better choice
If you choose a inflatable try to get a quality one not a cheapie (if you talk to a inflatable specialist they should be able to guide you)
Good luck
Regards Don
326629
Follow Up By: donk - Tuesday, Sep 23, 2008 at 12:28
I also want to add if you did have
wheels to drag the thing you would want to have your son sit on the side (could be unstable) or on a
seat mounted across the sides so as to not place any load on the floor when it is not supported by the
water
On
mine for fishing i have a couple of 1 inch thick marine ply sections that span from side to side that have velcro on the ends & these stick to matching velcro that is glued to hypalon sections that are glued to the hypalon side tubes
Otherwise i leave the seats off & sit on the side to drive the thing or for high speed fun in rough
water kneel on the floor to drive it
Regards Don
593854
Reply By: Richard W (NSW) - Tuesday, Sep 23, 2008 at 06:42
I carry a 10' rubber ducky I bought off Ebay with me. It's an Avon about 20yrs old and I run a 4hp motor. The setup works
well for one in enclosed waters. A bigger boat and motor as you propose should be good for 2. May be an issue to drag it with someone in it.
The ones with an aluminum floor might suite but defeats being able to store it in a small space.
326647
Reply By: The Landy - Tuesday, Sep 23, 2008 at 08:21
We (can) carry a 3.3M Quiksilver inflatable in the back of our vehicle and it is capable of taking up to 15hp. When we go outback we usually just take a small 3.3hp to get around the creeeks etc.
Fold up in about 15 minutes, wooden floor and very robust.
Otherwise sits in our garage on a trailer fully inflated and ready to go.
We find it a good compromise between having something we use all the time versus the flexibility of taking it with us when we go away.
326656
Reply By: Pete Jackman (SA) - Tuesday, Sep 23, 2008 at 18:59
We have a Porta Bote which is quick and easy to set up. 3 trips down to the waters edge - hull, seats and motor - then about 10 minutes to put it together. No worries about punctures and it planes with a 3.5 Hp outboard.
With a set of beach rollers you could assemble it near the 4by and your son could sit in it while you
trundle it down to the
water.
Pete
326771
Reply By: Corio - Wednesday, Sep 24, 2008 at 00:27
Thank you to those people that replied.Your information has been very hepfull.
326852
