Auxiliary Tank Sender Unit for a GU Patrol.
Submitted: Tuesday, Sep 23, 2008 at 10:42
ThreadID: 61937 Views:2871 Replies:5 FollowUps:1
Needing a Sender Unit for a GU....Have called heaps of wreckers but no one has one. Can anyone help??? Dont want an after market one.
Hayley
Reply By: Member - RFLundgren (WA) - Tuesday, Sep 23, 2008 at 10:56
Hayley
If you go to the Patrol 4 x 4 Forum and search for a member there called Nizzbits, he may be able to help you with a genuine part. It will be new but his proces are pretty good.
AnswerID: 326675
Reply By: Member - Hayley & Demc (QLD) - Tuesday, Sep 23, 2008 at 10:57
I found one!! $56 too so prretty chuffed with that.
Thanks anyway.
AnswerID: 326676
Follow Up By: bobsa - Tuesday, Sep 23, 2008 at 11:08
make sure you get the one for your model.
I have had the series1, 3 and 4 ,the Aux sendor unit may look the same but the little resistor thingy ( technical name ) that sends the information to the gauge is different, the reason I know this, is that I had long range tanks that I swap from vehicle to vehicle, and had modified a series 3, when I went to connect in the series 4 it would not work.
regards Bob
FollowupID: 593838
Reply By: Member - Hayley & Demc (QLD) - Tuesday, Sep 23, 2008 at 11:31
Hmmm ok
well we dont have a patrol... we're putting in a long range tank and are using the rear tank off a GU patrol. Hubs project not mine (obviously). I have no idea what series the tank he got is from.....
AnswerID: 326679
Reply By: Member - Murray R (VIC) - Tuesday, Sep 23, 2008 at 21:43
hayley
nissian and toyota fuel gauge senders are not compatable .May be try to get sender that suits your model surf and see if it can be adapted to the nissian tank.You will have to check that the float arm travel suits the nissian tank. If its adaptable you can remove the wire from the original tank sender, run it back to a two way switch (center off) then two wires back , one to each sender unt then just use switch to check each tank.
this migth help
murray
Another Mexican
AnswerID: 326830
Reply By: Member - Murray R (VIC) - Tuesday, Sep 23, 2008 at 21:56
ps
you could use 5 core trailor wire as this would be sleeved and just use three of the wires
Another Mexican
AnswerID: 326836
