Nissan ZD30 engine failures
Submitted: Tuesday, Sep 23, 2008 at 18:47
ThreadID: 61961 Views:16692 Replies:6 FollowUps:6
I have a Nissan Navara D22 with a ZD30 diesel engine and am concerned after reading this link regarding engine failures. I do oil changes at 5000km when towing and 10000km when normal driving. I might have to do all oil changes at 5000km. Any suggestions on what's the best oil to use.
Reply By: 3.0turbob - Tuesday, Sep 23, 2008 at 19:06
The concerns with the ZD30 engine are mainly in the early (2000, 2001) turbocharged Patrols. Do a search to read the horror stories.(you may have already) Nissan recommends a Semi Synthetic oil ACEA B3, you can buy it at the dealers. Check your owners manual. Not sure if Navara engines have failed, someone will know more.
Rob
AnswerID: 326772
Follow Up By: Member - 1/2A - Tuesday, Sep 23, 2008 at 19:15
Hi Rod,
The engine that failed in the link provided was a 2005 model with 60000km caused by faulty piston rings.
FollowupID: 593917
Reply By: Member - Mark G (NSW) - Tuesday, Sep 23, 2008 at 19:13
gday guys
my 2004 navara is serviced every 5000klm's and my mechanic uses Penrite oil. the women in the link didnt specify( i dont think) how often they serviced the nav'.
whether or not this makes a difference or not someone will be able to comment for or against.cheers.
AnswerID: 326776
Follow Up By: Member - Madfisher - Tuesday, Sep 23, 2008 at 20:55
The local Toyota service manager told me they recently traded a one lady owner Corrolla with 150000ks that appeared to have never had a service.
I have to fight with swmbo to get her to service her Paj and even then I have to pay for it. lol
So could be a connection.
Cheers Pete
FollowupID: 593946
Reply By: Michael ( Moss Vale NSW) - Tuesday, Sep 23, 2008 at 19:17
Regardless of what Nissan says, any modern, petrol or diesel should do 300,000 to 400,000ks if basic regular maintenance is carried out. Even those cheap Korean are still going at 300,000ks.. The 3 litre engine has been a disaster for nearly 10 years.. how Nissan have gotten away with it, we will never know. I know if it was a Holden and even out of warranty, they would have made good if there was a huge failure rate as has been with the 3.0L.. It really is a disgrace!! I'm not sure if the "best oil " is the answer.. Michael
AnswerID: 326777
Follow Up By: Member - Mark G (NSW) - Tuesday, Sep 23, 2008 at 19:24
MICHEAL
i agree with you there mate but you are asking for trouble if you use a 'K-MART' or 'woolies' brand oil. as for nissans customer care, yep its a bloody joke as i found out.all we can do is hope that our rigs hold together so we can enjoy them for what they are made for as long as they can,cheers.
FollowupID: 593921
Reply By: Ianw - Tuesday, Sep 23, 2008 at 19:40
Have not heard of any Nav ZD30s blowing up. Few small turbo probs but nothing major. I believe the Nav engine is a different casting than the Patrols.
Ian
AnswerID: 326786
Follow Up By: Member - Paul W (VIC) - Tuesday, Sep 23, 2008 at 20:16
and not the variable vane turbo!
FollowupID: 593932
Follow Up By: Malleerv - Tuesday, Sep 23, 2008 at 22:20
I know of 4 Navara's that have done in the ZD30 engines around here. They don't have a good name in this area any more. Pity, I like them.
Matt
FollowupID: 593970
Reply By: Member - Mick O (VIC) - Wednesday, Sep 24, 2008 at 06:41
Have you had a look on the Nissan Patrol Forum. You'll find a truck full of horror stories concerning the ZD30 engine (I've got one of them to tell myself). There's even talk of commencing a class action against Nissan as a result.
Mick
AnswerID: 326860
Reply By: JR - Thursday, Sep 25, 2008 at 07:15
Yep weve got one at work which died at 18mth old- not sure what went wrong but loud knocking noise just before we sent it away - still running though!!
JR
AnswerID: 327032
