Turbos on and tuned
Submitted: Wednesday, Sep 24, 2008 at 19:22
Member - Nick (TAS)
For those that dont know, I purchased a used DTS turbo and I/C, the turbo needing rebuilding.
Well after opening up the intake from
snorkel to airbox,having the turbo rebuilt, fitting a H/D clutch,dropping the sump off to braze on the oil return from turbo, replacing the inlet manifold with a custom built one, fitting the EGT gauge, custom made mounts for the I/C and pipe work,cutting a big hole in a perfectly good bonnet and fitting a bonnet scoop,boost controlled thermo fan on I/C today I finally rolled it out the door and tuned it all up.
And I can say what a transformation, it simply flies.I fitted a DTS turbo to my old 2.8 4 Runner and was very dissapointed with the final outcome.Not this time.Im running 11psi boost with a maximun EGT of 550deg C.But with the pyro fitted, will keep EGT's under 500 and set the alarm for 450.
Reply By: darrell.QLD - Wednesday, Sep 24, 2008 at 19:59
Thank god u done all that!!!!!!!!! i was really worried,,,,,,,,,,,,,,
326989
