gearbox problem?
Submitted: Thursday, Sep 25, 2008 at 14:58
Gossy
My 96 GQ 2.8TD doesn't like 2nd gear when it's cold. Needs an extra forceful push. No clunking, banging etc, just extra effort. After about 5-10 mins of driving when things are all warm it's as good as new. by good I mean absolutely no problem giving it a thrashing off road in high and low range so I feel confident there is not a problem in the short term BUT long term?
Any advice if there is a problem hiding away there? Rather ask here than a mechanic who will of course say there is a problem!
Reply By: traveller2 - Thursday, Sep 25, 2008 at 15:03
Better quality or different grade of oil might help, best talk to a 4wd mechanic as they should be aware of any pecularities of the box. Did read something somewhere that it is actually a car gearbox? Skyline, 300z etc?
327095
Reply By: Gossy - Thursday, Sep 25, 2008 at 15:08
using the standard oil recommended in the service manual (and only done about 5000km's ago before the Simpson).
I have heard the same about the gear box being out of a car. I have 230,000km's on the clock and most of that off - road so maybe it's on it's last leg?
cheers,
327098
Reply By: Member - Howard T (QLD) - Thursday, Sep 25, 2008 at 15:29
GDay Gossy
My Series 80 had a similar problem between 3rd and 2nd. Toyota Mechanic suggested I use VMX-M oil. Fixed the problem. Had around 50K on it at the time. Has now got 260K and had no problems.
Howard.
327103
Follow Up By: Lex M - Thursday, Sep 25, 2008 at 16:02
What
Howard T said. Castrol VMX-M
Had a similar problem and that fixed it.
594274
Reply By: Gossy - Thursday, Sep 25, 2008 at 15:32
I suspect it's oil but seems a bit odd that I am using the recommended oil and experiencing the problem. Maybe they get fussy as they get older!
Mechanical problem would be there either cold or hot.
I'll check tonight if I am using a thicker oil and if i can go a bit thinner.
327104
Reply By: Member - Fred - Thursday, Sep 25, 2008 at 16:10
Castrol suggested I use "Multitrax" in my GU 2.8 gearbox - no shifting problems when cold - change it as recommended at 40 000 km - now done 235 000 km
327114
Reply By: sweetwill - Thursday, Sep 25, 2008 at 16:47
hi gossy
after having a couple, your gear box sounds a lot like me in the morning very slugish and hard to free up cheers bill.
327118
Follow Up By: Gossy - Thursday, Sep 25, 2008 at 17:25
yer, tell me about it!
594290
Reply By: Gossy - Thursday, Sep 25, 2008 at 17:29
Oil it is then! good news. Dont have to beg the wife to spend money on a new gear box. Spoil myself with some Boags instead.
327125
Follow Up By: Willem - Thursday, Sep 25, 2008 at 17:51
Gossy
Had a look at the manual. The 4.2 gearbox Needs 75W/90 GL5 and the 2.8 needs 80W/90 GL4. I use Castrol Easyshift and a bit of Nulon Transmission additive just for good measure. My old truck gearbox has 367 on the clock.
Hope the new oil works wonders.
594297
Reply By: Member - Phil G (SA) - Thursday, Sep 25, 2008 at 20:06
Castrol VMX-M 75/85 fixed my Landcruiser, so I now use it in all our other vehicles - even the Xtrail changes better with VMX-M. I'd give it a go in your Patrol. Can be hard to get it, but
SuperCheap stock it now.
327156
Reply By: Gossy - Friday, Sep 26, 2008 at 08:54
thanks for your advice.
327230
