hi lux vs prado
Submitted: Friday, Sep 26, 2008 at 06:57
ThreadID: 62035 Views:2198 Replies:5 FollowUps:0
Hi there
Can any one tell me why the d4d desiel has the same klw output however the tourque is different. 360nm to 410mn.
thank you
tobyoden
Reply By: Member - Phil G (SA) - Friday, Sep 26, 2008 at 08:19
I may well be wrong as I'm just taking a punt, but I thought the Hilux had the older 5speed manual and 4 speed auto transmissions, while the D4D Prado came out with new (? stronger) 5 and 6 speed boxes, which could handle the extra torque. Also, I think the Prado has a stronger front diff.
AnswerID: 327220
Reply By: Member - John F (NSW) - Friday, Sep 26, 2008 at 08:28
Could be the way it is quoted - on my Hilux I think it's something like 343 Nm from 1400 - 2600 rpm, they didn't quote a peak as such.
Maybe just to make the Nissan owners feel better - I think there equivalent was about 410 Nm but at a silly 3000 rpm.
With the nature of torque curves there is obviously a higher peak figure between the 1400 and 2600 points on the Hilux - maybe that's the 410?
Or the ECU may be adjusted for the Prado?
Whatever it is they are great motors. Mine gets about 8.5l/100km driven sensibly. Even towing a 1.5 tonne this only drops to 12.5.
Regards, John.
AnswerID: 327222
Reply By: Notso - Friday, Sep 26, 2008 at 08:42
The same applies to the Mitsubishi Triton and Pajero, different Kilowatts and Torque figures.
Probably the gearbox limitations.
AnswerID: 327226
Reply By: chisel - Friday, Sep 26, 2008 at 10:23
Hilux is lighter (unladen) than Prado (right?). Probably tuned for best combination of performance/economy in the lighter vehicle.
AnswerID: 327243
Reply By: puttputt - Sunday, Sep 28, 2008 at 02:09
Yes, I believe it is the gearbox, the 5 and 4 spd boxes are only rated at 345nm, where the new 6 and 5 spd are rated higher. Even the petrol V6 prado was detuned to 345 nm when mated to the previous 5 spd manual box.
AnswerID: 327452
