Troopy handbrake
Submitted: Saturday, Sep 27, 2008 at 07:03
Member - lyndon K (SA)
I need to adjust my 78 (2004) Troopy's handbrake.
Can i do this just by taking the rear
wheels off and using a small screw driver to move the adjuster in the drum. If so do you move the adjuster up or down? I have the screws to pull the drums off, but think they will have to be unadjusted to allow them to come off? If so, apart from allowing me to clean them this doesn't serve much purpose.
Thanks for your help.
Lyndon
Reply By: Member - John F (NSW) - Saturday, Sep 27, 2008 at 08:46
Lyndon,
Why not buy a workshop manual, then you can do it, and a lot of other things, properly?
I know nothing of Troopies, but in the days before I saw the light and stopped fiddling with cars, I recall that to adjust the rear drums you wound the adjuster out until the wheel started to bind, then backed off one notch.
With the brakes properly adjusted you would then adjust the handbrake cable - either at the lever, or the yoke, or both. Are you saying the only adjustment is within the drums?
Taking the drums off would also allow you to inspect the wheel cylinders for any fluid weeping - something I would assume any good mechanic would check for; also allows a thorough check of the shoes and the meat left in the drums.
I'm sure there will be plenty of very knowledgeable replies from experts here, but I still feel that for things like brakes I'm happier to leave it to the professionals.
Regards and good luck, John.
327355
Follow Up By: Member - lyndon K (SA) - Saturday, Sep 27, 2008 at 12:39
Thanks John
Yes, i think the only adjustment is within the drums.
594589
Reply By: Top End Explorer Tours - Saturday, Sep 27, 2008 at 08:54
Hey Lyndon
Lift up the rear end, take off the tyres, using one large screw driver turn the adjusting hole to the bottom, using a smaller screw driver adjust the hand break adjuster up until it stops then move it down 3 turns, then replace
wheels.
Cheers Steve.
327358
Follow Up By: Nav 8 - Saturday, Sep 27, 2008 at 10:36
Slacken off the handbrake cable at the handbrake first, then readjust after the shoes are done. Nav.
594584
Follow Up By: Member - lyndon K (SA) - Saturday, Sep 27, 2008 at 12:42
Hi Steve
Thanks for that. I guess i will need both
wheels off the ground at once? I have factory diff locks so i think the rear diff is an open one, not LSD.
Is the only adjustment within the drums?
594590
Follow Up By: Member - Phil G (SA) - Saturday, Sep 27, 2008 at 13:07
Gday Lyndon,
This will help:
http://www.lcool.org/technical/80_series/handbrake.html
In reality, the only adjustment that needs to be done frequently is at the rear drums. The other adjustments at the backing plate and at the lever are rarely required. There is no need to remove the rear disc/drum.
The adjuster is just behind bottom centre - shine a torch in hole to see it. Normal size blade screwdriver is what I use.
The factory setting is to adjust the handbrake shoes tight, then back off 8 clicks, but the adjustment is best with just 4 clicks.
As Steve said, on both sides, adjuster up (screwdriver handle down) tightens it, and the reverse to loosen.
I find the LandCruiser handbrake works great if adjustment is done about every 20k.
594592
Follow Up By: Member - extfilm (NSW) - Saturday, Sep 27, 2008 at 23:26
good on ya Nav......
It is very important to loosen handbrake cable first........
594693
Reply By: disco driver - Saturday, Sep 27, 2008 at 15:57
Hi Guys,
From what I have read on this
forum (and others), it seems that the best handbrake for a 'Cruiser is a piece of hardwood about 300mm by 300mm by 150mm high.
Through one corner you drill a hole about 12mm diameter, attach a suitable length of cord through the previously drilled hole and place the said block either in front of or at the rear of any tyre, depending on whether the said 'Cruiser is facing down or up
hill respectively.
To release said handbrake either drive forward a little or back up a little as necessary and using the aforementioned cord pull the said block out and replace it on passenger side front floor ready for the next time the handbrake is required.
Trust me................It works!!
Disco.
327392
Reply By: Notso - Saturday, Sep 27, 2008 at 16:20
Mate, I adjust
mine by asking her nicely??
327395
