caster angle
Submitted: Monday, Sep 29, 2008 at 15:13
ThreadID: 62122 Views:6804 Replies:5 FollowUps:3
could somebody please tell me what the correct caster angle should be for a 80 series landcruiser 91 model gxl turbo,have been told +2 ,my straight line stability was ####house at -.75,have since turned housing back,driving very well now , cheers
Reply By: Hairs & Fysh (NSW) - Monday, Sep 29, 2008 at 15:25
Spend the money and get it done professionally.
Can't go wrong.
Easy
AnswerID: 327668
Follow Up By: elkhound - Monday, Sep 29, 2008 at 16:58
had the frontend aligned two weeks ago,problem being you can go wrong professionally as it turned out,but thanks for the input,may ring toyota tomorrow,like to know spec. anyway cheers mark
FollowupID: 594982
Follow Up By: Hairs & Fysh (NSW) - Monday, Sep 29, 2008 at 17:12
Hi Mark,
After I posted I though maybe that's why your asking, that they had stuffed it up.
Check out This Link It might be able to help you find what your looking for.
FollowupID: 594984
Reply By: Member - 120scruiser (NSW) - Monday, Sep 29, 2008 at 17:36
Straight from the manual
With 31 x 10.50 R15
265/75 R15
9.00-15-6PRLT tyres
Angle should be 1 deg 40 min +/- 60 min
All other radial tyres
3 deg +/- 60 min
Obviously yours has a lift in which you need the off set bushes if 2 or 3 inches but if higher you require the caster plates.
Scott
AnswerID: 327682
Reply By: mechpete - Monday, Sep 29, 2008 at 18:29
in most cases L/H/S has more caster than the R/H/S to offset the camber of the road which nornally causes most vehicles to run off to the left . get it done by the people who know their job .
mechpete
AnswerID: 327690
Reply By: Member - 120scruiser (NSW) - Tuesday, Sep 30, 2008 at 08:49
They only press out and you press the new ones in. Pretty easy but you do need a large press to get the old ones moving. You put the new ones in the freezer for awhile before you press them in and they go in easy.
AnswerID: 327753
Reply By: Sea-Dog - Tuesday, Sep 30, 2008 at 09:36
I found with my 80 that a 2" lift brought my castor angle to zero..
At 0 the drive was ok even with 305/70/16 muddies on board... when I went up a little higher and the castor angle got into the negatives the steering on the highways etc was shocking and I found that I had to continually steer the car..
I did a 2 degree correction which put the castor to +1 and the difference in drive is huge..
AnswerID: 327757
Follow Up By: elkhound - Tuesday, Sep 30, 2008 at 18:05
G,day sea-dog,you are spot on ,my 80 had supposeably 2 inch lift,drove OK? when i converted to dual cab i up graded too extra heavy coils 2 inch lift (supposeably)all round,put caster bushes for 2-3 inch lift in the same time,still drove airey fairy so to speak,just had it aligned -.75,they say it drives allright,couldn,t put up with it! so sloted front holes in support arms and stregthend brackets as well,driving like a 80 should . cheers mark.
FollowupID: 595143
