2003 FORD EXPLORER good option?
Submitted: Tuesday, Sep 30, 2008 at 14:46
MYMYTPAJ
Gday gang,, was interested to know whether anyone has had any experience with late model Ford Explorer's, i have always had Falcons in the past & never had a drama, and since the Explorer is using similar mechanicals,,,,,,,,is it a good option? I wont be using it for serious off roading,,mainly long trips with the family, but may need the off road option should the need arise.
Like to know your thoughts,,if you have any.
The
Pilbara Earwig
Reply By: beelzebug - Tuesday, Sep 30, 2008 at 15:01
MYMYTPAJ,
I am not an expert on
Explorers, but I think you will find it a far different animal to the aussie Falcon.
Developed for the US market with V6 (not inline) and V8 engines, the chassis and
suspension is not the same.
You would pick up one cheap though as they are now a bit of an orphan.
327789
Follow Up By: MYMYTPAJ - Tuesday, Sep 30, 2008 at 15:32
Thanks fella's thats given me something to think about,,, back to the drawing board i guess,,,,,,
Thanks for your time.
595120
Follow Up By: beelzebug - Tuesday, Sep 30, 2008 at 15:42
Why not get your own MYTPAJ?
There's plenty of them around that have never been offroad.
595123
Reply By: garrycol - Tuesday, Sep 30, 2008 at 15:03
They are not called EXPLODERs for no reason.
327790
Follow Up By: Redback - Wednesday, Oct 01, 2008 at 10:18
Read up on them before commenting, below by PajeroTD has it right.
You should know better Garry, tsk tsk tsk!!!
Baz.
595231
Reply By: aussiedingo - Tuesday, Sep 30, 2008 at 15:15
G'day all, I have only heard of them as a "Ford Exploder" as
well as they give trouble as they get older, check with your mechanic or RAC club - if it's not a Toyota it's not worth buying! You get what you pay for - if you don't pay much, you dont get much, they are always a lot cheaper. regards,
dingo
327794
Reply By: PajeroTD - Tuesday, Sep 30, 2008 at 16:16
They were called "Exploders" because of the Firestone tyre blowout issue. After Ford ditched Firestone, there were no more problems.... it's not really that hard to switch tyre brands. That one problem was only with the previous shape Explorer too (prior to 2001. They are a pretty good car, inexpensive, roomy in all 3 rows and pretty reliable and comfortable to drive. The re-design for 2001? 2002? Gave awesome improvements including IRS, which not only makes it more comfortable, but it's the main reason there is so much legroom in the 3rd row, and fold flat seats, which the solid axle didn't allow for. My only quarrel with the Explorer is you cannot shift the transfer case to a true 2wd, which means it uses a bit more
fuel than it needs to on the road (AWD), But it does have AWD, 4x4 Hi, and 4x4 Lo. I recommend just taking one for a drive and seeing if YOU like it.
327806
Follow Up By: MYMYTPAJ - Tuesday, Sep 30, 2008 at 16:51
Thanks for your comments PAJEROTD,, good advice,, i'm kinda torn between whether to stay with the Ford (since i know them) though this is a different cousin all together,,, or go the 2004 Pajero (which i have a TD1984 NA
Pilbara basher) which has also never let me down,, both choices im sure will do the job, so thanks again for your thoughts, i'll go have a beer & think some more!!
595133
Follow Up By: Member - DAZA (QLD) - Tuesday, Sep 30, 2008 at 17:32
We have one, use it as the spare vehicle,
Just a run down on repair costs,
*Front Wheel Hubs & Bearing, $1200-00 each,
*Auto Transmission repairs Under Warranty $4700-00,
*Thermostat $200-00 each,
Otherwise a good vehicle, would not take it on real off road Stuff.
Plenty of Grunt for Towing,
We run Coopers on ours, no Explosions yet.
595137
Reply By: Member - Graham H (QLD) - Tuesday, Sep 30, 2008 at 17:29
Some one will correct me if I'm wrong but dont you have to take the engine out to replace the timing chain as its at the back of the block. Believe they are also rather thirsty.
327810
Reply By: Ted G - Tuesday, Sep 30, 2008 at 18:35
We were previous Exploder owners, the following problem that none of which Ford was interested in fixing even though they were recalls in the US.
Ford said that the Australia car was a different car the only difference being that the steering wheel was on the right hand side.
The following problem was in 10 months the car had 50,000 klm on the clock at the start and 85,000 we we got rid of it.
1 Broken timing chain $3600
2 Problems with mixer body $600
3 Climate control running hot and cold $3,200 to fix a $30 valve, dash had to come out.
4 Tyres because two tyres had been changed before the recall they would not replace them,
5 Total cost of repairs nearly $8,000 plus lost $6,000 on the value of the car when sold.
Ford was not interested in any of the problems.
So after buying Fords for a fleet we ran but after the Exploder Ford no more.
Don't buy an Exploder
Ted
327822
Reply By: Member - Paul W (VIC) - Tuesday, Sep 30, 2008 at 20:50
if you dont mind spending about $4k to do a head gasket in them go for it! LOL
327853
Reply By: MYMYTPAJ - Tuesday, Sep 30, 2008 at 23:24
Thanks to all you concerned folks,, in particular Ted,, I think that was precisely what i was digging for,, I appreciate all your time & comments,, thank you.
327887
Reply By: Member - John F (NSW) - Wednesday, Oct 01, 2008 at 07:16
I was always intrigued at the way they sat on the road - low at the back, unladen. Don't recall seeing one loaded up; would not have been a good look. Ford seemed to overlook some design basics with that one.
John.
327900
