Suspension Upgrades for 78 Series Troopy,
Submitted: Wednesday, Oct 01, 2008 at 12:31
Geoff (Newcastle, NSW)
Hi Team,
The age old question,
suspension.
My 2006 model 78 Series is starting to sag in the rear end. A bit like those 2wd HiLux utes around town. (Why do they always remind me of a Blue Cattle dog with worms? If you wormed them would they stop dragging their arse?)
So I've been thinking. Dangerous stuff I know but someone has to do it.
As I see it I've got three choices,
1. It's still under warranty. So I argue with Mr Toyota and maybe get a new set of exactly the same.
2. Get these reset and in 2 years time do it again.
3. After market with a bit of lift and maybe get rid of the problem for more than 2 years.
Options 1 & 2 sound like ongoing work to no real advantage.
Option 3 sounds expensive but perhaps a little more permanent.
I'm also open to Options 4, 5 etc.
So based on Option 3 what are others using in their Troopy's?
Oh, I mainly beach fish and tour so I'm not a hard core offroader. Weight wise it's mostly unloaded but for a few weeks each year it can carry enough supplies for 2 people for say 2 weeks.
Over to you and thanks,
Geoff
| Geoff,
Reply By: Member - Leigh (Vic) - Wednesday, Oct 01, 2008 at 12:48
Been down the air bag route and it was a good option at the time but I wanted a bit more overall clearance for what I do. If you are not doing what you describe then that's what I'd recommend.
I have recently spent the bucks with a 2" lift and all that goes with that including remote canister shocks and are very happy with the result. A better ride as
well and good load carrying capacity in terms of maintaining a reasonable ride height at maximum load. Good for corregations.
Firestone kit number 2115 will fit under your troopy with a few minor modifications. Have a look at the Trucksprings site in the US and save some $$
Hope this helps. Cheers
327938
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 13:20
Hi Leigh,
Thanks, that is the sort of thing I wanted to know.
Out of curiosity what brand of replacement springs and shocks did you settle on?
Thanks,
Geoff
| Geoff,
595254
Follow Up By: Member - Leigh (Vic) - Wednesday, Oct 01, 2008 at 13:39
Hi Geoff. I went for OME through ARB Dandenong. Cheers
595258
Reply By: Wayne (NSW) - Wednesday, Oct 01, 2008 at 13:24
Geoff,
I went for the TJM springs and shocks all round.
On the 75 Series I had the rear springs were too hard an when the vehicle was empty it was like a Nissan Ute.
This time round I went for the medium lift with bellows on the rear. This has given me ride height, weight carrying and comfort.
Wayne
327942
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 13:53
Hi Wayne,
Thanks for that, much appreciated.
By bellows do you mean air bags such as the Firestone one's Leigh talks about above?
Geoff
| Geoff,
595260
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 13:56
Hi Wayne,
I think I just answered my own question by looking at the TJM website!
You'd have Poly Air Bellows is my guess!
Geoff
| Geoff,
595261
Follow Up By: Wayne (NSW) - Wednesday, Oct 01, 2008 at 14:09
Geoff,
It was a good thing that the Troopie is still on jack stands.
Image Could Not Be Found
Wayne
595262
Follow Up By: Michael A (VIC) - Wednesday, Oct 01, 2008 at 15:04
Wayne
Just had the bellows fitted to
mine and I am very happy. Thanks for your advice.
Michael A
595274
Reply By: furph - Wednesday, Oct 01, 2008 at 14:13
I have had Polyair bellows on the back of my '97 trayback for about 10yrs. Absolutely faultless.
Because the back end height remains regardless of the load (adjust air pressure to suit) the front end carrying a TJM commercial steel bar and winch was a bit low.
I overcame this by installing a pair of Monro pump up shocks on the front. About 45psi makes a world of difference.
Thing about all air lift systems, they have to be valved/piped independant to each other.
It also means that in rough country I can pump nearly 2" of lift into the rig and still get a reasonable ride.
furph
327948
Reply By: Member - Dick (Int) - Wednesday, Oct 01, 2008 at 14:17
Hi Geoff
I did a TJM upgrade including increasing the GVM to 3,600kg. Also fitted Polyair's so I could adjust the ride height for various load conditions. It is very firm when empty but it is always partly loaded so not much of a problem. All the work was done by Grant at TJM Hunter Valley.
I have a 180L Aux
tank in the back so when it is full there is a lot of weight in the rear.
If you want to look at my Troopy you are welcome.
327949
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 15:02
Hi Dick,
Thanks for that information.
I was going to drop in and see Grant this afternoon.
With very little effort TJM can be made to be on the way home for me.
Sounds like yours has a little more weight in it than
mine.
Geoff
| Geoff,
595273
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 20:11
Hi Dick,
I dropped into TJM this afternoon on the way home and looked at their
suspension gear, got some prices and ideas etc. They sure know how to charge!
Shockies at $160 each, leaf springs at $350 a pop! Coils at $230 a pair, shackles and pins at $160! Then add $55 for u-bolts plus another $160 for urethane bushes.
Then add another $716 for the bellows and it's up to $2,658 without fitting!
I also priced a bullbar as I'm in the market for a steel winch compatible unit. At the moment it'll be an ARB commercial as they are $300 cheaper than the best TJM could do. (Both supply only)
Interesting exercise when the guy patently hasn't got a clue what the bullbar looks like without a picture let alone what fixtures it has. Easy to see the hilift attachment points in the picture but I still don't know for certain if it has "D" shackle attachment points. I'm pretty certain it has 2 driving light tabs and 1 aerial tab.
Anyway, after asking about Grant and getting the avoidance strategy it turns out he sold the business at the end of the last financial year (30th June) and has moved back to
Bundaberg to run his other TJM store.
For me at the moment TJM gear looks the goods but I'm not overly sure about the local product knowledge anymore!
Geoff
| Geoff,
595333
Follow Up By: Member - Dick (Int) - Wednesday, Oct 01, 2008 at 20:55
Geoff
I should have mentioned that Grant has sold the business. He stayed on until end of Aug to let Ken get settled in and a couple of weeks ago when Alan (my son) called up he was in the
shop again. He still has a house and a boat in
Newcastle. The place he has in
Bundaberg is an ARB
shop.
There are some very knowledgeable staff in TJM but it sounds like you did not get them today. Ring my son and ask him who is the best to talk to there. I think you probably need Darrel.
My Troopy has a TJM Type 13 Steel Bar on the front with a Hyd Winch in it so you can have a look at it if you want to. We had to weld an additional Antenna mount on this bar as originally it was on my 79 Series and we had the HF Antenna on the bar. Now it is mounted on the rear bar.
As to prices, they are not cheap but as a package you can probably get some discount. I carry spare shocks, bushes and U Bolts so I have a hell of a lot invested in the
suspension.
TJM and ARB are both convenient sources but if you want to
shop around I am sure you can get springs from Lovells on a better deal. We went the TJM route on
the springs as we wanted their approved package to increase the GVM.
My son Alan has organised all the work on my vehicles so give him a call anytime. He trades from home so is always there including most weekends if that suits you better.
595341
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 21:43
Hi Dick,
Thanks again for your help.
Your take on what Grant is up too is interesting, I'd assume you got your information straight from the man himself! The bloke I was talking to today told me Grant had gone to
Bundaberg to get his
shop there up to TJM Megastore standard, no mention of ARB!
I'll certainly ring Alan for a look at your Troopy. You've got the exact setup I'm looking to eventually create right down to the Ox hydraulic winch.
Good gear is seldom cheap. I've been thinking after I posted the earlier prices, this gear really hasn't gone up in price in nearly 20 years!
Dad's mate and I both had 1980's vintage Troopy's at the same time.
Mine was the first of the current shape complete with the venerable 2H diesel.
Bob, dad's mate got an Ultimate
Suspension kit fitted to his and it was $2,100. That was 4 leaf springs, 4 shocks, steering damper, bushes and shackles including the fitting!
I've just been quoted basically the same amount today!
Thanks again,
Geoff
| Geoff,
595350
Reply By: Member - Phil G (SA) - Wednesday, Oct 01, 2008 at 17:53
Gday Geoff,
I went ARB 2" lift because they make good leaf springs, and because I'd heard the ride was good. I've had them for almost 4 years now, and done 70,000k of mostly trips. I got their heaviest front coils and their "400kg" leaf springs, but soon added an extra leaf to bring the rears up to their "600kg" springs. The ride was good; the load carrying was OK, but the traytops do sway a bit (no rear sway bar like your troopie).
So earlier this year I bought a set of BOSS airbags for the rear and it simply makes the rear end adjustable. Fully loaded, the rear end sits at whatever height you like. And the sway has gone.
I also fitted the greasable shackles, but IMO they are a waste of money. The poly bushes are not as good as the original Toyota bushes that have nice steel sleeves, and move better.
327980
Follow Up By: Member - John (Vic) - Wednesday, Oct 01, 2008 at 18:06
Phil I have heard stories of the poly bushes "Binding up" and causing leaf's to break due to lack of movement/flex??
Any thoughts or experience on this note?
595310
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 20:40
Hi Phil,
Thanks for the feedback on the ARB gear. The local
Newcastle store is about 300mtrs down the road from work. I'll take a walk at lunchtime tomorrow and see what they can offer.
Intersting comments on the urethane bushes. I've never used them, always the genuine Toyota rubber ones along with the standard pins and shackles.
The Toyota stuff seems to last
well and is easy to get hold of.
Goodness, over 25 years ago in
Weipa I managed to grab some for my HJ47! Back in those days
Cape York Toyota was just a tin shed down near the harbour. The bloke threw a box at me and said, "there should be a few in this box" and he was right!
The Firestone airbags from Trucksprings in the US sound far more economical than the TJM offering.
I'll look into your BOSS units too.
The bags may
well be a good starting to point to level the cruiser out whilst I make a decision on
the springs and more importantly save some pennies.
Geoff
| Geoff,
595338
Follow Up By: Member - Phil G (SA) - Wednesday, Oct 01, 2008 at 21:37
Gday John,
I hadn't heard of leaf springs breaking because of poly bushes binding. Most leaf springs I've seen break have been old ones on corrugated roads.
Geoff,
I'd guess the ARB guys will have a slightly different opinion to me. I think their OME springs are very good. I think the factory Toyota shocks are the best for outback travel, and less likely to fail or fade than aftermarket shocks. I've taken the OME shocks off and put the Toyota ones back on. I think the Toyota sleeved bushes and shackles are stronger and move better than the greasable shackles and polybushes on the 78/79series.
The Boss bags are OK - I bought them off Ebay for a bit over $500. The quality looks fine to me and equal to the Polyairs. The downside to the airbags are that you will reduce rear articulation - by about 70mm for the uptravel. Really only matters if you are rockhopping.
595348
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 21:56
Hi Phil,
Again interesting your comments on Toyota shocks v's the OME units. I might float that one past the ARB crew tomorrow for a laugh!
I had pretty much guessed that airbags would reduce the rear articulation but wasn't sure by how much. Yes, you are 100% correct with
the rock hoppers comment!
I did a Google search and came up with this crowd in
Brisbane for Boss bags,
Boss Airbags
I'll also have a good look on eBay for them and probably the Firestones too.
Geoff
| Geoff,
595352
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Oct 02, 2008 at 09:10
Hi Phil,
I'd guess these bags are something like the ones you have in the rear of your 79,
ebay Boss Airbags
Isn't the whole 78-79 Series idea difficult for these 4wd shops to grasp?
Straight forward according to Mr Toyota, you have a 79 Series, I have a 78.
Yours is a cab-chassis,
mine is a troopy.
Geoff
| Geoff,
595384
Follow Up By: Member - Phil G (SA) - Thursday, Oct 02, 2008 at 14:55
Yep, same Ebay seller, same deal as
mine.
I know quite a few people with these fitted to their traytops but none on troopies. I'm guessing that traytop owners are more likely to put extra weight in and are also bothered more by the sway from the lack of a rear swaybar. If I were you, I'f just go with better springs and if you find out later that you'd like airbags, then get them later.
595441
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Oct 02, 2008 at 16:50
Hi Phil,
I've been thinking some more about the idea of putting bags under my troopy before I look at springs and I've pretty much come to the same conclusion as you.
I'm better off saving the dollars at the moment and doing
the springs and shockers first. After all my original problem is-was sagged rear springs!
I'm still no closer to a brand choice as my replies are 50-50 spilt between ARB and TJM. Even price doesn't help, ARB want $1,848 supply only and TJM want $1,942 supply only. They are even within $3 of each other for fitting! (If I was a cynic I'd say they've been trained by the oil companies)
I'll give Dick's son a ring after the long weekend and go check out his troopy first. At least I'll get a look at TJM's offering.
Thanks again,
Geoff.
| Geoff,
595458
Reply By: Member - Tour Boy Springsure- Wednesday, Oct 01, 2008 at 19:25
I agree about bushes,
after 37 cruisers and 4 luxes I will only use rubber bushes now as the urethane ones seem to get crud stuck in them and seize up. The rubber ones (even the cheepies) last longer and respond better when greasable shackles are used. They are also easier to install and remove.
Dave
327993
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Oct 01, 2008 at 20:42
Hi Dave,
Do you use rubber grease in the greasable shackles with the rubber bushes or do you use something else to lube them?
Geoff
| Geoff,
595339
Reply By: Member - Tour Boy Springsure- Thursday, Oct 02, 2008 at 15:37
I use the
grey coloured graphite grease. It doesn't attract the dust like others.
Dave
328141
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Oct 02, 2008 at 16:31
Thanks Dave,
Much appreciated!
Geoff
| Geoff,
595454
