How should I maintain a caravan to prevent it developing leaks
Submitted: Thursday, Oct 02, 2008 at 20:28
ThreadID: 62226 Views:2414 Replies:2 FollowUps:1
I'm thinking of buying a van maybe 20 years old and if I can get something in reasonable condition I am wondering how I should maintain it.
Any advice at all would be appreciated,thanks in advance.
Reply By: Member - Mick O (VIC) - Thursday, Oct 02, 2008 at 21:17
Cruiser,
The one I've heard and seen used is the "Very Bright Light Test". Brother used this method to dust seal his Jayco. In a dark shed or on a very dark night, have someone crawl around inside the van with a very bright light working their way around all the seams and joins from the interior of the van. At the same time, someone outside is following their progress and looking for light. Where they see it shining through an edge or seam, it's marked and siliconed up.
Mick
AnswerID: 328203
Reply By: Member - Reiner G (QLD) 4124 - Friday, Oct 03, 2008 at 07:48
The safest way would be clean off anything you see on old sealers and re-seal with sikaflex. The right way is remove all the corner trims and hatches, reseal with mastic. Put it all back together and clean off excess mastic with mineral turps.
Reiner
AnswerID: 328227
Follow Up By: Member - Reiner G (QLD) 4124 - Friday, Oct 03, 2008 at 07:51
forgot to mention do the same with the windows. New vans have a foam tape behind the window frame but the old ones had mastic or putty. Remove the windows and reseal with mastic. You can buy the right mastic at Camec in your state.
Reiner
FollowupID: 595527
