Caravan & Camper Battery Charging Feedback
Submitted: Friday, Oct 03, 2008 at 12:48
bazza j
hi have a new (UN USED 120amp batterywaiting to install in caravan i only have a 5amp charger in the van wat size do i need to charge bat on 240vt cheers barry
Reply By: Member - Graham H (QLD) - Friday, Oct 03, 2008 at 15:05
that will do it just takes longer so Im told anyway
328276
Reply By: Affordable Batteries & Radiators - Friday, Oct 03, 2008 at 16:32
Have you got specs on the charger.
You need a good charger so the AGM dos not build up sulphation.
Derek.
328283
Reply By: Member - Norm C (QLD) - Friday, Oct 03, 2008 at 19:20
If you run the battery down to 50%, you need to replace 60 AH. Even assuming 100% efficiency, that will be 12 hours of charging to fully charge with a 5 Amp charger (with no load). If you are running a fridge or other stuff, it will take much longer.
Being a 5 Amp charger, I suspect it is a cheapie. You really should invest in a reasonable quality multi stage (smart) charger.
Most AGMs can handle high charge current, so you can do the maths yourself on charge time v cost of a bigger and better charger.
Might cost you $200 or more (depending on size), but it is money
well spent. You will get the best out of your battery and the battery will last much longer if you are charging it correctly.
Norm C
328322
Follow Up By: Member - Norm C (QLD) - Friday, Oct 03, 2008 at 19:26
Check out Derek's web site (post above this one). He normally has good prices on stuff like this. No relationship - just a repeat customer.
ABR Sidewinder link.
Norm C
595573
Reply By: Richard & Leonie - Friday, Oct 03, 2008 at 22:34
Simple rule of thumb is the charger should be able to deliver at least 10% of the batteries amp/hr capacity. ie 120 amp/hour battery should have at least 12 amp charger. Bigger is better. Get a 20 amp three stage charger. Xantrax is probably the best on the market. Ring Derek at ABR and he will have what you need. I have 2/ 105 amp hour batteries in my camper and have a 40 amp charger. Your 5 amp hour will take too long to charge the batteries.
Richard
328357
Reply By: bazza j - Saturday, Oct 04, 2008 at 11:40
hi all thank you all for all the helpful advice i havenow 3STAGE 17AMP HEAVT DUTY sh/circ&rev/pol protection it should do the job happy motering to all cheers Barry
328403
