Dust in the Cab
Submitted: Friday, Oct 03, 2008 at 17:56
Dagoth
Does anyone else out there have problems with dust coming in to the cab aad tail
gate area of there Nissan Navara?
Reply By: Member - Lance S (VIC) - Friday, Oct 03, 2008 at 18:02
Dagoth, last trip i had, had heaps getting in and thought about getting an air vent for the top of the canopy, then someone here recommended to leave the side window open and couple of inches and all will be fixed, he was right.
cheers,
Lance
328293
Follow Up By: Dagoth - Friday, Oct 03, 2008 at 18:07
I don't have a canopy on the back. My problem is that it is coming in either through the door seals or the doors them self. Nissan has told me that there is no problem with the door seals them selves.
595564
Reply By: Member - Mick O (VIC) - Friday, Oct 03, 2008 at 18:08
I went to Clark Rubber and got sticky sided 25mm neoprene tape (about 8mm thick). Put that round the inside edge of
the tub so the tailgate closed against it. This plus leaving the front sliding window of the cannopy open 100mm while travelling does the trick. It's always going to get in tho mate.
Mick
328295
Reply By: Member - Phil G (SA) - Friday, Oct 03, 2008 at 18:43
Do you drive with the windows up, and vents on "fresh"?
328308
Follow Up By: Dagoth - Friday, Oct 03, 2008 at 20:37
Yes the windows are up . Not sure if the air was on fresh. My hilux 2000 does not have this problem thou.
595583
Follow Up By: Member - Phil G (SA) - Friday, Oct 03, 2008 at 23:34
If vents are on fresh, then the cab gets pressurised.
595610
