Engine noise in Rodeo
Submitted: Friday, Oct 03, 2008 at 20:51
Member - Rod V (WA)
Would anyone have any clue of what would cause engine noise low down, it was ok then was getting hard to start, now can start it but theres a something trying to get out
Can anyone shed some light on it
Reply By: oz doc - Friday, Oct 03, 2008 at 21:10
Hey Rod, do we get some more clues? What vintage rod and what sort of noise? Under load?, at idel? etc. Cheers, doc.
328341
Follow Up By: Member - Rod V (WA) - Sunday, Oct 05, 2008 at 14:01
hey Doc, ok it rattles as soon as you start it, when you turn the engine with spanner you here the sound when No2 cylinder is open at top, when you turn the motor back you hear the same sound, to it sounds like something spring loaded flicking back the motor is 2.8 1996 vintage with 189000kms on the clock, been an expensive excerise, owner has changed turbo, waterpump, steering pump and injectors all for advice for so called mechanics
regards
Rod
595758
Follow Up By: oz doc - Sunday, Oct 05, 2008 at 19:48
MMMM- interesting. Does it become any quieter after it has warmed up a bit?doc.
595817
Follow Up By: Member - Rod V (WA) - Monday, Oct 06, 2008 at 08:20
No stays there all time
595876
Reply By: Notso - Friday, Oct 03, 2008 at 21:20
If it is low down on the engine, it could be big end or main bearings.
If it sounds like marbles rattling around, more than the normal diesel noise then it's most likely big end bearings. The mains will be more heavy sounds.
If it's higher up then it could be piston slap, or gudgeon pins
328342
Reply By: Member - 120scruiser (NSW) - Saturday, Oct 04, 2008 at 06:29
The late model diesel's make a horrible rattle at and just above idle. Sounds like there is no oil in them but its just the way they are.
328378
Follow Up By: Member - Tony B (QLD) - Saturday, Oct 04, 2008 at 17:08
Funny. My 06 work and 07 Play are both very quite at idle. Funny how others can get a different idea. Cheers Tony
595676
Follow Up By: Member - Rod V (WA) - Sunday, Oct 05, 2008 at 14:05
Strange I'm always piston and broke
595760
Follow Up By: Malleerv - Monday, Oct 06, 2008 at 18:19
There is a cold start valve on the injector pump that adds more
fuel at idle when first started. If this valve is faulty they will run rich at idle and just above giving a stronger that normal diesel knock. It its been faulty for a while you may think this is a standard engine noise. Its not and should be looked at but a pump specialist.
Personally I think Rodeo's have the noisiest engine on the market but thats just my opinion.
Matt
595973
Reply By: Malleerv - Saturday, Oct 04, 2008 at 10:46
If it is a 2.8TD 4JB1 engine it could be the timing gear bolts. They have a habit of coming loose. Could also explain the hard to start.
Matt
328397
Follow Up By: Member - Rod V (WA) - Sunday, Oct 05, 2008 at 14:04
gaday Matt
Do you have to take off the crankshaft pully to remove the timing cover or is there an easier way of doing it
Rod
595759
Follow Up By: Malleerv - Monday, Oct 06, 2008 at 18:14
Yes the pulley needs to come off. There are some small bolts holding the gears on and they can come loose and break or drop off.
Matt
595970
Reply By: Member - Lionel A (WA) - Saturday, Oct 04, 2008 at 15:55
Rod, my Nissan does the same.
As soon as I start it, the engine noise begins.
Sorry mate, couldnt resist it. Hard day at the office and its beer time.......hahaha.
Cheers mate.....Lionel.
328420
