Problems with selecting 4WD in 04 Rodeo Diesel.
Submitted: Friday, Oct 03, 2008 at 21:28
ThreadID: 62259 Views:23278 Replies:4 FollowUps:5
Has anybody with this type of vehicle had any problems with the electrical system that selects four wheel drive.
Thanks Dave
Reply By: Member - Peter D M - Saturday, Oct 04, 2008 at 05:46
hi dave
your question is a little vague any particular symptom?
regards peter
AnswerID: 328376
Follow Up By: David Cooke - Saturday, Oct 04, 2008 at 22:15
The problem was that I could not select 4x4 as the electrical system was dead along with my Tacho & Speedo.It was solved by replacing an electronic box under the seat.I just wondered if anyone else had that problem.
FollowupID: 595710
Follow Up By: Member - Peter D M - Sunday, Oct 05, 2008 at 07:51
now we know the area of concern.
i havn,t heard of that problem, but had some 'electronic boxes' under bonnet replaced due to engine cut out.
the other responses are standard rodeo issues.
my major 4x4 selct problem was a year back when i could not get out of low range after playing with wires and checking connections we located a damaged speddo sender plug on the gearbox somehow this was stopping it disengaging. rewired and away we went.
regards peter
FollowupID: 595718
Reply By: P7OFFROAD Accredited Driver Training - Saturday, Oct 04, 2008 at 06:27
My 'other' work vehicle is a Rodeo.
The 4wd selection is haphazard and random at best.
I have spent quite a bit of time at the edge of bitumen waiting for it to decide if it's going to let me get back on the road and go home.
We have a number of them in the organisation (though no new ones, they have been replaced by Rangers which are a thoroughly better vehicle) and apparently they are all performing as designed (according to Holden)
as an aside, the noise level in my dualcab is 82dB. 85dB is the limit for noise that you can be exposed to all day...
I hate that car.
AnswerID: 328377
Follow Up By: Member - Tony B (QLD) - Saturday, Oct 04, 2008 at 17:02
Your opinion
"they have been replaced by Rangers which are a thoroughly better vehicle) and apparently they are all performing as designed (according to Holden)" The Holden Rodeo came second to the Triton in the 4 x 4 mag tests and only a narrow second and it beat the Ranger/Mazda. Nothing wrong with the Rodeo, you do have to follow the correct proceedure or you will have lots of trouble. Cheers Tony
FollowupID: 595674
Reply By: Member - John D (VIC) - Saturday, Oct 04, 2008 at 11:43
Hi Dave,
I have an '04 Rodeo 4wd, and have had no problems with going from 2H to 4H, which can be done on the fly at speeds around 80 kmph. But if going from 2H to 4L you have to be stationary and have neutral selected, then press 4L, on occasions (when on a hill/slope) I have found that 4L doesn't engage properly and that I have to select 1st gear and gently ease out the clutch a couple of times and then 4L engages and all is ok.
If for any reason your Rodeo is or seems to be "stuck" in 2WD or 4WD then below is instructions to reset the system which was given by a Holden dealer.
1. Ignition off, hold all 3 buttons (2H, 4H & 4L) in together.
2. Switch ignition on to the "reds" position (last position before actual engine ignition).
3. Hold in this position for 30 seconds.
Hope this helps Dave,
Regards, John
AnswerID: 328404
Follow Up By: Member - Tony B (QLD) - Saturday, Oct 04, 2008 at 16:58
Yes had troubles with my new Rodeo 07 model until you do it correctly. It is a bit of a hassel but once you get used to it its ok. 2WD To H4WD is no problem any more. You can do that on the fly, just be steering strait ahead. H4WD TO L4WD and back again is the trick. As stated above you must be stopped and have neutral selected, I have found foot off clutch. If it wont go in you just have to rock it a bit forward and then reverse and try again. Coming out of low 4 x 4 IS THE HASSEL. Gets stuck a lot and you have to reverse quite a distance someimes to let it unwind. If this fails I have always had a win when you shift it to neutral by holding any of the buttons down for 30sec and then selecting the gear you want and hold it for 30 sec. Now it is not so much of a problem any more - just be sure to be in Low 4 x 4 before you get to the hazzard, once in you have to do the neutral trick most of the time. Cheers Tony
FollowupID: 595673
Reply By: Axel [ the real one ] - Sunday, Oct 26, 2008 at 19:19
Just bought a 04 dual cab turbo diesel auto , prior to pickup vehicle went to the original dealer to effect a recall , you guessed it , even though the vehicle no longer under factory warranty holden will /must fix the recall as it is a fit for purpose problem.
AnswerID: 331996
Follow Up By: Member - Cookie & Di - Monday, Oct 27, 2008 at 14:50
How & where could I find more info on this recall?
FollowupID: 599973
