towing camper trailer
Submitted: Saturday, Oct 04, 2008 at 13:14
ThreadID: 62271 Views:2816 Replies:4 FollowUps:0
I am wondering if an offroad jayco camper van would be easier to tow on the beach than an off road camper trailer?
Reply By: Notso - Saturday, Oct 04, 2008 at 13:51
I suspect the Jayco would be harder than an Off Raod camper Trailer, but I suppose it depends on the tyres, the weight, the track width etc.
AnswerID: 328409
Reply By: Tony - Saturday, Oct 04, 2008 at 13:57
I think the Jayco would be a lot wider than a camper trailer. You would be draging another set of tyres.
My camper has the same wheel width as the vehicle, so only one set opf wheel tracks.
AnswerID: 328411
Reply By: joff1 - Saturday, Oct 04, 2008 at 14:38
I pulled my Hawk over to Fraser a few years back. It was pretty hard going in the soft stuff. Track width, tyre pressures and weight are the variables to look at. The jayco is wider and heavier than a lot of normal campers.
AnswerID: 328412
Reply By: Member - Bucky (VIC) - Sunday, Oct 05, 2008 at 07:23
You can tow anything on the beach or sand, but what will make it better to tow, is that you make sure that you drop tyre pressures, in your vehicle and your camper.
I find that what ever I take the 4B's pressure down to, I then take the camper 3 - 4 psi lower. Works on foot print, and it's one of the best things I have discovered, or should I say was taught !
Safety side of things, less pressure, less speed. But if you need momentum, then its on for only as long as you need it.
Bucky
AnswerID: 328482
