Out of a bog with diff lock
Submitted: Saturday, Oct 04, 2008 at 22:54
peteC
Haven't tried this yet, but has anyone tried putting a snatch strap around your rear tyre ( around the tread ) and tie off to a tree etc, engage your diff lock to pull out of a bog. I guess if the strap slipped off it could do some panel damage, but with a bit of care and taking your time I assume it would do when all else failed.
Reply By: Crackles - Saturday, Oct 04, 2008 at 23:18
May work but far too many other options for a recovery for me to risk wrecking a snatch strap or squashing my brake lines in that manner.
Cheers Craig................
328468
Reply By: disco driver - Sunday, Oct 05, 2008 at 01:18
Not yet.
But if you keep watching I'm sure some f**kwit will post his attempts on that universal "Look at me" known as U-tube.
Should be hilarious watching him destroy panels.
On a similar idea there are available attachments that bolt onto the wheel hubs which allow one to use rope or cable in the same way as your idea. there were comments on this site but I cannot remember the name of the attachments.
Someone else may be able to help.
Disco.
328476
Follow Up By: GoneTroppo Member (FNQ) - Monday, Oct 06, 2008 at 15:55
Seem to recall it was a Milemarker, US product from the 60's
595942
Reply By: Member Brian (Gold Coast) - Sunday, Oct 05, 2008 at 06:45
A snatch strap isn't designed for this sort of thing.
If.... IF.. I was to try this, then I would probably try it with a tow or winch extension strap.
Brian
328479
Reply By: ExplorOz Team - Kerry W (QLD) - Sunday, Oct 05, 2008 at 09:30
Hi Pete,
Fair Question, but in reality it would be almost impossible to get the strap to run straight on the tyre,(if you could get it under the tyre and locked off),very hard to turn the wheel slowly enough to stop the strap slipping off and probably a really quick way to lose a finger or two. (Or the brake lines and panels, as already mentioned)
This device is called the Joey - one of a few devices around.
These devices work
well but are not overly popular as they are bulky and require a bit of work to put on and take off (as
well as clean).
Mind you once you are stuck in a salt pan everything you do takes a lot of work.
I find Maxtrax to be quicker and easier though
Image Could Not Be Found
They are good insurance though as you can also have dual
wheels on each side of the vehicle or use em as a winch.
Kerry W
| Kerry W (Qld)
-Helen KellerLifetime Member My Profile My Blog Send Message |
328496
Reply By: aussiedingo - Sunday, Oct 05, 2008 at 12:50
G'day all, I have a set of these joey's as
well, are great as with the dual
wheels you can off set them & in mud they will lift the inner wheel to hop along slowly to keep you on the move, seee yaa
328526
Reply By: neilbis - Sunday, Oct 05, 2008 at 15:55
also a brand called the "bush winch". Type it in google and it comes straight up. I think i seen a post on this one before from memory. This one seems simple enough, u swap out your wheel nuts for the "special ones" which u leave on all the time and the adaptor just slides and twist on....sounds simple enough
i didnt get one because it sounded like a a bit of a dodgy/more dangerous way off winching plus $800-900
328540
Reply By: Nutta - Sunday, Oct 05, 2008 at 23:19
I actually got stuck coming down a deep rutted
hill one day, all
wheels fell into ruts and i was sitting on my diffs, i only had the snatch so put it around the tyre, it was enough to get me out of trouble and home anyway.
328595
