Fuel Filter Nissan Navara
Submitted: Sunday, Oct 05, 2008 at 09:59
PeterG ACT
I thought I would do the right thing and change the
fuel filter on my Nissan Navara Diesel Turbo 2004 model before I head of on my big trip tomorrow. The problem I am is once I changed the filter,filled the
fuel filter with with diesel, primed it up the vehicle now won't start. My question is has anyone else had this problem and does anyone have any suggestion on what I may be doing incorrectly? Any help would be great.
Reply By: Dunaruna - Sunday, Oct 05, 2008 at 10:11
How did you prime it?
328501
Follow Up By: PeterG ACT - Sunday, Oct 05, 2008 at 14:58
Thanks for your reply, it finally started.
595764
Reply By: Member - Lance S (VIC) - Sunday, Oct 05, 2008 at 10:16
You still must have air the in lines, try priming it again and let it flow out, then connect hose back up.
cheers,
Lance
328503
Follow Up By: PeterG ACT - Sunday, Oct 05, 2008 at 14:59
Thanks Lance, I finally got it started. I'm not sure if I will try that again, might leave it to the mechanic next time.
595766
Reply By: mechpete - Sunday, Oct 05, 2008 at 15:09
its not primed properly ,
mechpete
328532
Reply By: Voxson - Sunday, Oct 05, 2008 at 18:40
yeah thats right..
Pump the primer till it gets hard,, then wait a mo and do it again and again and again and again...
then it will start...
328560
Reply By: Member - Bucky (VIC) - Monday, Oct 06, 2008 at 05:00
I got caught bad once, but I put together this routine, and still do it today, on the Patrol.
I would loosen off the
fuel cap, and make sure that the
fuel tank(s) was full. Dunno if it does anything, but I recon anything like that will help.
I would help the hand primer by just attaching some clear
fuel line to the outlet of the filter, and sucking diesel into the filter.
The idea is to suck the diesel into the clear hose, so you can see what's going on, and not get a gut's full.
Then I would hand prime. never had it play up on me again
Also make sure that you have put a little greasearound the "O" rings, to help seal them, and make sure that the drain plug is secure, on the bottom of the filter,and that the sensor wire is connected.
Bucky
328611
Follow Up By: PeterG ACT - Monday, Oct 06, 2008 at 09:57
Thanks Bucky, your advise was very helpful, finally got the thing started. First Nissan 4x4 I have owned, always owed landcruiser's before, things are a little different on the Nissan.
595882
