Powerwinch problem
Submitted: Sunday, Oct 05, 2008 at 14:24
ThreadID: 62297 Views:3248 Replies:2 FollowUps:2
I have a Powerwinch 912 to haul my boat onto its trailer. There is a black plastic knob that you tighten to change it from free spool to pulling. Lately this has started to self tighten as I winch in putting a bigger load on the winch and requiring a set of stilsens to undo it even though it should only be hand tight Something is wrong. Any one out there familiar with this winch and could advise of the problem and solution?
Mal
Reply By: Member - Roscoe ET (QLD) - Sunday, Oct 05, 2008 at 14:49
Ma,
I don't have your winch but I do have one I bought from SuperCheap which i suspect may have that similar black knob. Mine has done a similar thing on a couple of occasions.
I found that the knob was getting a bit hard to tighten and loosen off so I loosened it right off and greased the thread and the washer that the knob screws in against and it fixed the problem.
Anyway this worked on my winch.
AnswerID: 328529
Follow Up By: Member - Mal W (NSW) - Sunday, Oct 05, 2008 at 22:09
Thanks, I'll ckeck it out and maybe give it a try. Need to be careful where any of the grease ends up I would think
FollowupID: 595850
Reply By: Member - Nev (TAS) - Sunday, Oct 05, 2008 at 15:07
Hi Mal,
http://www.powerwinch.com/powerwinch/controller?action=contact
This url is the contact page for Powerwinch in the USA. Maybe leaving a note about the problem will get you some advice from them. Worth a try. I have had a couple of dealings with US firms with fishing gear and so far have always found them extremely helpful. In one case I lost the spring clip off my Scientific Angler fly reel. I asked them if I could buy a replacement and they sent me 5 for free and then followed up a few weeks later to make sure all was OK. PENN were also very accommodating when I had a hassle with one of their reels and sent me a free handle.
Rgds
Nev
AnswerID: 328531
Follow Up By: Member - Mal W (NSW) - Sunday, Oct 05, 2008 at 22:10
Thanks will try this before attemting suggestion above
FollowupID: 595851
