Fuel usage in W.A. N.T. vs Vic & S.A.
Submitted: Monday, Oct 06, 2008 at 22:04
Avan
I have just travelled from Vic thru SA and NT then down the WA coast back to Vic. I kept exact
fuel records, used cruise control ( 85kph) always and found that my diesel usage was 6.6% better when in NT and WA.
I used two jerry cans of
fuel in W.A. that were filled and carried from Vic. and found that the economy immediatly dropped. When I re filled using WA
fuel the economy improved.
Vechile was a Prado 3L turbo auto
I have heard that
fuel available in NT and WA is different from what comes out of Victoria.
Has anyone else found the same?
Reply By: Member - Brad S (SA) - Monday, Oct 06, 2008 at 22:36
Avan, you may be on to something.
I'm lead to believe that SA gets all its diesel shipped direct from Singapore and WA also gets a fair bit from SE Asia but it is better quality being blended with "Gas to Liquid" Diesel. This I understand is available as a "super" branded diesel...so it may depend on where you fill up yer
tank.
I stand to be corrected on this, as my only source is reading around a lot and none of it particularly authoritative.
Brad
328719
Reply By: Kroozer - Tuesday, Oct 07, 2008 at 00:41
I worked for various companies including
Mobil for a few years in a
fuel farm here in WA. When the tanker arrives there are many tests that the
fuel has to pass before it allowed to be discharged. Then while it is being discharged it is continually monitored and sampled to make sure it is to the correct specs. I mainly worked with Diesel and it alwasy came from Singapore. The
fuel in the last couple of years just got better and better, some loads were almost clear. The clearer it was the better it was processed. This is the
fuel that
services the
Kimberley and i can say that i am yet to see Diesel that was as good as the stuff we got there. I am unsure if you could break it down to different states getting better
fuel, as the Tankers do discharge at a couple of Ports before heading off to refill. That said though when demand is high and Tankers are few and far between, they could take the not so flash diesel and just mix it with large quantities of better Diesel. Alot of the Diesel also has other fuels in it too, as its all pumped down the same lines, and in some storage facilities it is very hard to determine when the 2 products have changed in order to switch tanks. I even know that in some cities in Australia the storage facilties are a long way from the Port, so that
fuel has got a long way to travel along buried pipes that wouldnt be too flash looking.
328727
Reply By: Barry 2 - Tuesday, Oct 07, 2008 at 01:26
Hi Avan
I am impressed that you keep such precise
fuel records !
I'm a lazy bugger, when the
fuel gauge reads empty, I fill up ??
Safe travels
Bazza
328729
Reply By: Member - Captain (WA) - Tuesday, Oct 07, 2008 at 01:49
Hi Avan,
In WA, most diesel comes from BP and they have BP Ultimate available, similar to Premium Unleaded petrol. It has a higher cetane rating (diesel equivalent to octane) and has a lower sulfur level. Not all stations have BP Ultimate diesel, even some BP outlets don't get the Diesel Ultimate
fuel all the time so it pays to make sure the outlet is BP and they advertise Ultimate Diesel if you want the good stuff. I go out of my way to ensure I only use BP Ultimate diesel, check the BP website for more info.
Captain
PS. Usual disclaimers, no affiliation to BP
328732
Follow Up By: Member - Brenton H (SA) - Tuesday, Oct 07, 2008 at 09:15
Hi Captain
Have you noticed any difference in your
fuel economy using the Ultimate Diesel product compared with the normal
fuel.
Brenton
596054
Follow Up By: Member - Captain (WA) - Tuesday, Oct 07, 2008 at 10:54
Hi Brenton,
I have only ever filled up with BP Ultimate diesel, right from new (~9,000kms ago) so do not know the difference with any other type of
fuel. I have visited the BP refinery (I am a Chemical Engineer) and saw the difference in equipment and technology used to make it and that is why I go out of my way to make sure I use it. Nothing actually wrong with other diesel, but Ultimate is just better so why not use it.
Captain
596064
Reply By: Mike Harding - Tuesday, Oct 07, 2008 at 08:09
Did you factor in both prevailing winds and day to day wind speed changes?
Mike Harding
328740
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Oct 07, 2008 at 09:01
Good point Mike,
On our last trip, we found consumption varied by 2 to 3l/100k depending on prevailing wind, i.e. head wind or tail wind.
That is trying to sit on 90/95. Found dropping to 80/85 makes a similar difference.
Even came across a few
grey nomads who had decided to stay put for a few days because of a strong headwind.
Down
hill makes a difference too. Such as dropping off the central plateau onto the coastal plains.
596053
Reply By: Zebra400 - Tuesday, Oct 07, 2008 at 09:23
As
well as wind conditions, terrain is another important factor. If you were travelling through the Great Dividing Range in NSW & Victoria, then you will most likely use more
fuel than the generally central & western parts of Oz.
I have been spreadsheeting our
fuel consumption since we bought our 4WD. We do a lot of offroad as
well. Every fill shows a different usage even when we don't do offroad. It also inlcudes travelling in WA, SA, Qld, NSW, Vic & Tas.
Having bought
fuel in other states on a regular basis, my
fuel stats do not show that some States are always more
fuel efficient.
328749
Follow Up By: Avan - Tuesday, Oct 07, 2008 at 09:52
The tail winds we received were observed and probally helped the S.A.
fuel consumption data which still could not come up to the figures in WA and NT. We did not travel thru the Great Dividing Range in Vic. however the hills in South West W.A. were probally about the biggest we traveled thru yet the
fuel consumption there was typically better than in Vic and SA. The
fuel was purchased from either Mobile,
Caltex,or Shell where we could take advantage of the 4cent discounts. I accept it was not a scientific data where all conditions are known (winds, degree of and length of slopes etc.) but certainly the variation in consumption was obvious.
596056
Reply By: Member - Tom V (WA) - Tuesday, Oct 07, 2008 at 20:28
Avan
answer is easy. look @ a map of Aust.
NT to WA is downhill. ??
LOL
cheers Tom.
328827
Reply By: Wimmera - Tuesday, Oct 07, 2008 at 22:20
Hi Avan
Well done for keeping your
fuel records and you will gain some insight into improving your
fuel consumption.
Unfortunately as others have suggested it is not that simple.
To add a few more variables that would affect consumption.
Fuel Temperate, Air temperature, Altitude, Specific gravity of
fuel (weight) probably regulated now but the heavier the better.
You will also find that Diesel purchased during winter is a better product as it is blended to to work in the cold weather, this is to prevent wax forming and varies throughout the year.
328844
