Vacuum for 4.2 Patrol Deisel, 98 model.
Submitted: Tuesday, Oct 07, 2008 at 06:58
ThreadID: 62341 Views:2576 Replies:2 FollowUps:1
I'm having a bit of trouble with brakes and clutch pedal pressure, and have a feeling it could be low vacuum.
Does anyone know what the vacuum should be at the pump?
Reply By: Member - Bucky (VIC) - Wednesday, Oct 08, 2008 at 04:07
If your motor is going, then you should have enuf vacuum.
The first thing I would do , would be checking the hoses for splits.
you should be able to hook up a vacuum guage, to practically anywhere on the inlet manifold, and do a rough check
Sounds like a perished, or blocked hose !
Bucky
AnswerID: 328869
Reply By: Member - Bucky (VIC) - Wednesday, Oct 08, 2008 at 04:34
Just had a look in my manual, and I cannot find anything. But it is only 4:30 am.
Something else I would be looking for.... make sure that your inlet gasket is not cracked, or you have a bolt missing, somewhere. as this will cause dramas. In saying that, is there a performance drop ?
Bucky
AnswerID: 328870
Follow Up By: Tony - Wednesday, Oct 08, 2008 at 06:56
Thanks Bucky, I found the problem. It is a leaking clutch booster. There is 26lb vacuum at the pump, which is fine for this elevation.
FollowupID: 596172
