How do you fix hard to wind up/down windows in a 60 seris?
Submitted: Tuesday, Oct 07, 2008 at 20:17
ThreadID: 62358 Views:8512 Replies:8 FollowUps:3
Hi all
I wonder if anyone knows how to fix stiff to wind up/down window in a 60 seris/
I have pulled door skin off and lubed all slides / moving parts i can see and it helps but still very stiff. Strangly they seem to be ok at times and then not at other times?
It seemed to help a bit also when i lube the top section where the window slides up into the door frame with dry glide, but still not as easy as they should be and soon return to as hard as ever.
Help
Kind Regards
GN
Reply By: oldpop - Tuesday, Oct 07, 2008 at 20:27
Hi GN
Remove door trims lube winder mechanism and spray rubber window chanell with silcone lube brand new
regards
Oldpop
AnswerID: 328826
Follow Up By: Member - G N (VIC) - Tuesday, Oct 07, 2008 at 20:38
Hi Oldpop
I have removed the trims and lubed the winder mechanism,
and have lubed the rubber channel but with "CRC dry glide"
I will try silicon lube, I am not familiar with it, is it a pressure pack type product?
Kind Regards
GN
FollowupID: 596134
Reply By: oldpop - Tuesday, Oct 07, 2008 at 20:41
GN
CRC make a silcone lube from memory its crc 808
Regards Oldpop
AnswerID: 328829
Follow Up By: Member - G N (VIC) - Tuesday, Oct 07, 2008 at 21:30
Thanks again oldpop
will try this and also the graphite recommended and will let you know whats does the best.
thanks
GN
FollowupID: 596146
Reply By: Dave B (NSW) - Tuesday, Oct 07, 2008 at 20:48
I use powdered graphite on my window channels.
Don't forget the rear door wnioiws too, they usually don't get used that often, and a likely to bind up without use.
Dave
'Wouldn't be dead for quids'
AnswerID: 328831
Follow Up By: Member - G N (VIC) - Tuesday, Oct 07, 2008 at 21:29
will try this on 2 and Oldpops silicon on 2 and will let you know how it goes.
Thanks GN
FollowupID: 596145
Reply By: ross - Tuesday, Oct 07, 2008 at 22:04
It could be the rubber slides are worn and this allows the window to tilt diagonally which jams them up.
I have tried everything suggested in this thread and resigned to the fact I need new rubber.
A good clean in the rubber slides and the edge of the glass can help
AnswerID: 328842
Reply By: S&N - Tuesday, Oct 07, 2008 at 22:30
rock?
AnswerID: 328849
Reply By: Cape York Connections - Wednesday, Oct 08, 2008 at 06:10
I have one of these bits of 4wd history and when I wind the windows up and down I am just happy to struggle and feel proud that I have one.LOL
Thanks I will try the above ideas also.
All the best
Eric
AnswerID: 328871
Reply By: Member - Phil G (SA) - Wednesday, Oct 08, 2008 at 11:03
The other thing that can happen is that the channels rust, squashes the rubber and the windows become tight.
AnswerID: 328890
Reply By: Shaker - Wednesday, Oct 08, 2008 at 14:01
Try powdered graphite in the slides in the top of the door frame.
AnswerID: 328903
