Natmap 2008 Problem
Submitted: Tuesday, Oct 07, 2008 at 21:53
Member - Stephen L (SA)
I have been using OziExplorer now for over 4 years with the Natmap 2003 Maps with no problems at all. Recently upgraded to the new 2008 Natmap Digital Maps. Loaded the new Ozi upgrade for the new maps, loaded the new DVD to the hard drive and all seemed OK. Connected up the other day as usual for moving map with the GPS and within about 10 seconds it went from the Mosaic maps straight to Landsat 7 Mosaic. I stopped the moving map and loaded the 250k Mosaic no problems. Started the moving map again and the same thing. Stopped moving map again, loaded the 2003 mosaic map, started moving map and again went straight to the Landsat Mosaic. The only way I could resolve this problem was to remove the Landsat Mosaic file from the hard drive and no more problems.
Has any other person with the new 2008 Natmap series had similar problems?
Reply By: Member - Andrew (QLD) - Tuesday, Oct 07, 2008 at 22:25
Sounds like a moving map control issue....
In the Moving Map Control box make sure the following buttons are selected (as taken from the Ozi help file):
Check for more Detailed Map - If this button is depressed then OziExplorer will search for a more detailed map at the interval that has been set in configuration. If a more detailed map is found then it will be loaded.
Look for Maps in Folder of Currently Loaded Map - If this button is depressed then when searching for a new map (leaving the current map) or for a more detailed map the search will only be done in the folder which contains the currently loaded map. If the button is not depressed then the "Map File path" and its sub-folders will be searched.
Hope that helps
Andrew
328845
Follow Up By: Member - Stephen L (SA) - Tuesday, Oct 07, 2008 at 22:37
Hi Andrew
I have just checked the Moving Map Control box and the check for more detailed maps was ticked. I will load the Landsat File again and un tick the tab and see what happens.
596151
Follow Up By: Member - Andrew (QLD) - Tuesday, Oct 07, 2008 at 22:44
The "check for more detailed map" button is causing the 10 second change of map, though either button can fix the problem. The other button will stop it searching other directories IF you have only the natmap topos in the one directory (without any other maps like the landsat etc).
Andrew
596152
Follow Up By: Member - Stephen L (SA) - Wednesday, Oct 08, 2008 at 08:01
Hi Andrew
Loaded the Files again, un ticked the check for more detailed maps. Just have been outside with the GPS and the issue solved. Thanks for your help.
596177
Follow Up By: Member - Andrew (QLD) - Wednesday, Oct 08, 2008 at 09:06
No problems Stephen....
Andrew
596184
Reply By: Pete Jackman (SA) - Wednesday, Oct 08, 2008 at 10:51
I had exactly the same issue with Natmap 2003. The .map file for the landsat indicates better pixel resolution than the 250k mosaic even though they are the same nominal scale - Ozi assumes that better pixel resolution = better scale and switches maps.
I also have the same issues with the NSW 1:100,000 and VIC 1:50,000 topo maps when travelling near the border. The NSW maps have a better pixel count and Ozi switches to them which is annoying as they show nothing on the ViC side of the border where the VIC topos at least show some detail on the NSW side.
Pete
328889
Follow Up By: Member - Stephen L (SA) - Wednesday, Oct 08, 2008 at 13:05
Hi Pete
This was a strange problem that I never had with the 2003 Natmaps loaded, only when I upgraded to the new 2008 Series. As above, I un ticked the check for more detailed maps and the problem solved.
596204
Reply By: The Explorer - Wednesday, Oct 08, 2008 at 18:09
While we're on the subject a new release version of OziExplorer was let lose a day or two ago
Version 3.95.4s
328935
Follow Up By: Member - Stephen L (SA) - Wednesday, Oct 08, 2008 at 21:36
Hi Greg,
I have updated to this new version. One thing that you have to do when you get the new 2008 Natmap series is go to the OziExplorer site and download the new Map File Path.
596285
Reply By: Von Helga - Wednesday, Oct 08, 2008 at 20:48
I have had a couple of issues from time to time where the config settings change (for whatever reason) and to assist in trouble shooting and so I don't have to use my brain to remember what they were set to, I have screen dumped each tab of the config file to a word doc so I can return to my baseline settings if/when they change of their own accord.
328974
Follow Up By: Member - Stephen L (SA) - Wednesday, Oct 08, 2008 at 21:48
Hi Von Helga
This is the first time that I have had a problem with OziExplorer, and I hope the last. With help from members on this site it is now all sorted out.
596286
Follow Up By: Member - Andrew (QLD) - Wednesday, Oct 08, 2008 at 22:04
It is much easier to just copy the "oziexp.ini" file to another directory and then restore it when necessary. EVERY setting of Oziexplorer is contained in that text file.
Andr
596287
