arb diff lockers
Submitted: Wednesday, Oct 08, 2008 at 14:41
ThreadID: 62376 Views:3926 Replies:6 FollowUps:10
gday to all.
just a quicky i hope lol.
am i barking up the wrong tree.are there any advantages of having diff locks in the sand.if so front or rear locker.
main princple will be towing the camper remote area when we do the csr etc or boat when on the barra.
any info 4 or against be welcomed
jason
Reply By: Robin Miller - Wednesday, Oct 08, 2008 at 14:58
Absolutely Jason
Over last few days I travelled with an 80 series through 11km of firebreak track (my gu4800 towing a trailer ) , I bogged down and couldn't keep traction with the 80 series , engaged both lockers then he had trouble following me.
Soon after that we found a sand hill bigger than Big red - I shot straight up it , and watched and filmed over the next 1/2 hour my 3 friends trying to get up and in was classic front drivers wheel only spinning (as it had least weight on it) which stopped them right in front of us.
Could not be a clearer demo.
More suspension travel makes locker advantage less though in sand as elsewhere.
AnswerID: 328906
Follow Up By: Robin Miller - Wednesday, Oct 08, 2008 at 15:48
I notice your question is 2 part Jason.
Just quickly lockers are least useful when you have even
distributed pressure over your 4 wheels, so driving the wheels
puts equal ground force on all of them and hence minimal
slipping occurs, hence lockers not so useful.
The collary is that when ever the force on your wheels
is not equally distributed then its more likely that a wheel will slip
and that slipping wheel needs control.
When towing a trailer you put more weight on back wheels, making the front lighter.
The lighter front end will lift or bounce a wheel more when a hole or side slope is encountered, and effect is worse uphill.
Hence front benefits more from locker in most senario's.
FollowupID: 596212
Follow Up By: Member - Matt M (ACT) - Wednesday, Oct 08, 2008 at 18:44
Robin,
Was the 80 series a part time (DX) or full time (GXL) 4WD?
Not disagreeing with your conclusions, but a spinning front wheel wont affect the drive to the rear two if the centre diff lock was engaged (assuming it is fitted). Without individual diff locks, the 80 should only be in trouble if one front AND one rear wheel loses traction.
Matt.
FollowupID: 596230
Follow Up By: Robin Miller - Wednesday, Oct 08, 2008 at 19:48
Part time Matt - no disagreement there , the front is just the most obvious going uphill
FollowupID: 596251
Reply By: OzTroopy - Wednesday, Oct 08, 2008 at 15:30
Check out the availability of OX lockers for your vehicle ... much more reliable than electrical / air operated bling systems.
AnswerID: 328910
Follow Up By: Flywest - Wednesday, Oct 08, 2008 at 16:21
Also consdering lockers for an 80 series - what are OX lockers & how do they differ from Air pressure or electric solenoid operated lockers?.
Lastly - whos the best 4wd place in WA to buy & have installed a front & rear locker on a 80 series?
FollowupID: 596217
Follow Up By: OzTroopy - Wednesday, Oct 08, 2008 at 16:43
OX lockers may be a bit of a bum steer unless you have a jeep or F250 ......
Might still be worth an e-mail to them though.
http://www.ox-usa.com/ox/
Simple cable operation ... Only activates / disconnects when you make it do so ... not when you have an electrical short / loss of air pressure etc.
FollowupID: 596219
Follow Up By: joff1 - Wednesday, Oct 08, 2008 at 18:09
Is there a reliability issue on ARB air lockers that I'm not aware of?
FollowupID: 596226
Follow Up By: OzTroopy - Wednesday, Oct 08, 2008 at 18:24
I do know of a couple that have had problems ... but that could be style of use too.
My comment was based on the " the more simple the design ... the less to go wrong " rule.
The more electrical cabling and pressure lines you have running around under your vehicle ... the more likelyhood it will get ripped out by that stick on the track.
FollowupID: 596228
Reply By: Member - Phil G (SA) - Wednesday, Oct 08, 2008 at 19:10
I've never felt a need for lockers on any desert/beach/4wd training trip, and especially not on a 2002 Prado. Plenty of people I travel with have lockers, and I'd hazard a guess that no one ever engaged them.
Beware of the locker engaged/ not engaged comparison. When you fit lockers, you have the rear LSD removed, making your vehicle less capable with lockers disengaged than it was before.
AnswerID: 328952
Reply By: Member - Doug T (NT) - Wednesday, Oct 08, 2008 at 23:50
Traveln
Best you read the info in the link here and get the true facts
Diff Lock Info
AnswerID: 328998
Follow Up By: Member - Russnic [NZ] - Thursday, Oct 09, 2008 at 08:22
An informative link Doug T
Axle Diff locks are useful when the circumstances require the use, on a straight drag up a dune, in my opinion they don't achieve a lot except perhaps where the dune is that scalloped out traction may be lost with a wheel lifting off the ground.
If the terrain you are travelling could result in a wheel coming off the ground that is when Difflocks work best, have two wheels off the ground and still have drive, not "Dry Bogged", to me the biggest advantage is that with locking up both axles you can slowly climb through rough ground where without Locks you would need a lot more momentum to get through, causing the possibility of other damage to both vehicle and cargo.
A lot of drivers are not aware that with Difflocks engaged the vehicle will want to carry on in a straight line and be reluctant to turn,more so in greasy, slippery,and soft sand conditions.
Pop up over the top of a dune and as the bonnet comes down you see a big blow out in front and then wonder why the vehicle won't turn, probably the Locked Diffs won"t let it.
FollowupID: 596324
Follow Up By: Member - Doug T (NT) - Friday, Oct 10, 2008 at 15:43
Russnic
I have had the experience on 2 visits to the Simpson Desert and your theory is incorrect, (I talk Auto Lockers only) and had no problems turning what so ever ,
In my opinion dual lockers work best when all 4 wheels are in contact with the ground, 4 wheels driving is better than 3 .
in greasy, slippery conditions I do agree with your comment,
Your last comment is why Auto Lockers are far better in that situation.
FollowupID: 596546
Reply By: Member - DickyBeach - Thursday, Oct 09, 2008 at 05:33
Jason,
I have a #80 with diff locks and a few years ago painlessly did the CSR towing a Kimberly Kamper - my Modus Operandi for many of the sand hills was to engage the DLs and take the hills slowly thereby not bouncing or ripping up the track; not once did I "let her rip" as was occasionally heard over the radio from other vehicles within radio range.
Never looked like having problems.
DickyBeach
AnswerID: 329006
Reply By: cowpat - Thursday, Oct 09, 2008 at 11:52
Jason,
In my opinion diff locks are generally not useful in sand, particularly once tyre pressures are lowered appropriately.
Exceptions where they are nice but not necessary:
1. steep dunes with big potholes/corrugations where others used too much right foot with too high tyre pressures - you can go slow and easy
2. big blowouts on dunes that don't have detours around them yet
3. at speed engaging the diff locks will keep the car tracking straighter, don't forget to unlock for corners
4. really steep dunes where you need to take a run up, even with the tyres at 10 psi, but this is only for fun as there is always an easier way up
Sorry I don't tow a camper but mostly I think you'd want lockers for rocky rather than sandy conditions.
Casper
AnswerID: 329047
Follow Up By: Member - Doug T (NT) - Friday, Oct 10, 2008 at 15:47
Casper
Your comment No 3 is something you don't have to worry about with full Auto Lockers .
FollowupID: 596547
