Projecta Battery Charger
Hi All,
We have a 105 amp Thumper. Can anyone please advise if the Projecta 4300mA Battery Charger ( Automatic 12 Volt 6A)will be ok to maintain the Thumper whilst we are not using it. Would it be safe to leave attached to the battery for long periods between use or best to use to charge occasionally.
I dont really want to spend up big on a Ctek if this one i have will do the job.
Any help would be appreciated
Cheers Tony
Reply By: AdlelaideGeorge - Wednesday, Oct 08, 2008 at 15:45
I've just bought an SM1207 7000ma 3-stage automatic Projecta to charge my Fullriver 120 ah AGM and 550CCA calcium marine batteries.
It's all so confusing nowadays-I've just noticed that the handbook states this charger is for lead acid batteries! I'm sure I saw something about suitable for AGM etc on the box - I don't have that with me now.
Anyway it's 3 stage automatic and seems to be charging both batteries just fine.
Your Thumper is a gel battery and I would think this 3 stage I've got would be the one for that type - but then again I'm no expert!
Mine cost $129-00 in Adelaide.
Happy days
George
AnswerID: 328912
Follow Up By: Sand Man (SA) - Wednesday, Oct 08, 2008 at 19:24
George,
The Thumper contains AGM batteries, not Gel.
Bill.
Bill
FollowupID: 596243
Follow Up By: Maîneÿ (wa) - Friday, Oct 10, 2008 at 11:16
Bill,
some AGM's are Gel
Mainey . . .
FollowupID: 596503
Reply By: Mike Harding - Wednesday, Oct 08, 2008 at 17:06
It would appear to have a 0V8 hysteresis around the nominal 13V8 float voltage which suits most (all?) lead acid technologies. That is not idea for the long term maintenance of batteries and I would expect some sulphation to occur.
http://www.projecta.com.au/documents/item/35
Maintenance of lead acid batteries in storage is _very_ simple and does not require complex chargers - all that is needed is a current limited 13V8, 1 amp plug pack or similar ($25?) and to ensure the battery is stored as close to 20 degrees C as you can manage.
This is the closest I can find:
Jaycar PSU
Mike Harding
AnswerID: 328923
Follow Up By: wheeleybin - Friday, Oct 10, 2008 at 08:01
Not as simple as one thinks as recently I had an abalone boat with two identical battery banks one a cranking bank and one a house bank with separate chargers both identical .
The cranking bank had problems after 6 years the house bank was still working perfectly.
The float was 3.8V per cell on both banks and within the top end of the manufacturers specifiifed float.
The results were the house bank was continuously under load and although getting to float rarely stayed on float.
The crankers were continuously on float and should have been set at the bottom end of the specified float.
The problem is now overcome by rotating the banks bi monthly between cranking and house duties.
So refering to manufacturers guidelines is a must for long term floating and using an adjustable charger is a bonus.
Some AGM and Gels are voltage sensitive and over time 13.8 float can shorten the batteries life.
Ian
FollowupID: 596479
Follow Up By: wheeleybin - Friday, Oct 10, 2008 at 08:05
Sorry 3.8V float is totally wrong it should read 13.8V per 12V battery.
Ian
FollowupID: 596481
Follow Up By: Mike Harding - Friday, Oct 10, 2008 at 13:45
Your batteries were not in storage, they were in use - different considerations apply.
Mike Harding
FollowupID: 596523
Follow Up By: wheeleybin - Friday, Oct 10, 2008 at 18:22
Yes I understand they would have been in trouble earlier if in storage with the same floating voltage to maintain them it was just too high.
Ian
FollowupID: 596581
Reply By: Member - Tony B (QLD) - Wednesday, Oct 08, 2008 at 17:09
I have that same charger always connected to both of my Marine Batteries and switched on full time. Keeps them charged for when I am ready to go. Suits me turn it on and forget until I need to go fishing. Cheers Tony
AnswerID: 328926
Reply By: Member - Roger B (VIC) - Wednesday, Oct 08, 2008 at 22:13
I've got a 'Battery Fighter' 3 stage charger from SuperCheap. Cost around $75.00 and does the job on wet cell batteries up to 80 AH. Mines only a 75AH and it maintains it with no problems. Cheers.
AnswerID: 328992
Follow Up By: gonebush SA - Thursday, Oct 09, 2008 at 09:08
hi, just out of interest how long does the battery fighter take to charge a battery (75ah) that is down a bit, we have looked around and some take 20plus hours which is to long if we are only staying some where with power over night?
thanks from chris.
FollowupID: 596328
Reply By: Member - Roger B (VIC) - Thursday, Oct 09, 2008 at 19:18
Probably no good to you Gonebush. The Battery Fighter takes a couple of days to get to the fully charged state, if the battery is a bit down. It's ideal to leave hooked up in the garage between trips.I just use a simple $20.00 charger for quick charges when necessary, while on the road.
AnswerID: 329107
