wind up coromal/goldstream/jayco
Submitted: Thursday, Oct 09, 2008 at 15:52
ThreadID: 62402 Views:7040 Replies:6 FollowUps:4
Hi Everyone,
Just wondering what the thoughts are from anyone who has taken any of the above or other offroad windup campers, actually offroad. I would like to buy one but just wonder can they hack the outback. I assume they would be sturdier than your average offroad caravan and easier/lighter to tow. But will they cut the mustard on some of the more out of the way tracks. I am thinking parts of the Kimberley, Cape York to the tip, Plenty highway etc. Also any of the girls out there my wife is a bit worried about if you want to pull over for a quick cuppa whilst on the road. How easy is it to access your equipment to do so with a wind up? Any tips would be appreciated.
Ta John
Reply By: Boobook2 - Thursday, Oct 09, 2008 at 17:27
Goldstream make one of the sturdiest of the three. I got one with air suspension and it is a dream on tracks. Couldn't be happier.
I went though the same thoughts before buying and while I have yet to try any of the above tracks with the van I have read many people who have done the kimberleys inc Mitchel falls and Bungle bungles. Cape York would be a no no though. do a search here
http://www.campertrailers.org/
The off road ones are wel built but the weight and size will be the main issue for things like the cape.
There is a fold down picnic table, bbq and outside cupboard for roadside stops. No real need to wind up.
AnswerID: 329085
Follow Up By: Goona - Saturday, Oct 11, 2008 at 16:22
Boobook2,
We have taken ours to the Cape and did the OTL on the way up. We even did Gunshot but this was apparently pretty tame this year. The worst one was Palm Crossing but we did this without incident. We also did all the water crossings and Nolans was over bonnet. All we did was tape up the door and the fridge vent prior to plunging on through. I was getting through parts of the OTL where others were getting stuck and all it takes is preparation, driver attitude and walking it first to find the best line.
Would I recommend then you bet. Would I by one again from the dealer in Brisbane definitely not.
Goona
FollowupID: 596727
Reply By: HGMonaro - Thursday, Oct 09, 2008 at 18:33
We have a Goldstream and have taken it up to Drysdale Station in the Kimberly (and the rest of the GRR). Didn't take it into Bungle Bungles but there were some Jayco's in there so the Goldstream would be ok. If you get past the 1st creek crossing the rest is easy.
We did have one problem with it which I put down to the corrugations. The winch worked itself loose and fell into pieces. Temporarily fixed at the time, properly fixed in Broome and then replaced back at the factory after we returned. Recently took it to the Flinders Ranges and it was fine. Everything alse about it is robust. Cupboards shut like new, etc.
Not sure they are much light than a normal van, only differnce is a few walls. Our 'offroad' version is high enough that you can't see over it out the rear window (Prado) so visionwise, same as a full van.
I have photo's from recent trip but not uploaded anywhere yet (can't add them here). Am writing a trip report but haven't finished it yet, but we took it along some '4wd' tracks. Manoeuverability (due to size) and rear overhang are the biggest issues doing that. Dirt roads are no problem.
When we stop for lunch we wind it up just enough to open the door (1cm or so) to get at the fridge and food (we don't like pre making our lunch). Takes 1min tops to open or shut so no great deal for us. We use the drop-down table to make our lunch on and hold drinks, etc. If that sounds too much trouble (it will to some, but we like to walk around at a break, not go in a van and sit down again) then you would need to set up your 'quick cuppa' requirements to be carried and accessable in your vehicle.
You don't mention, it but I'm going to presume you have kids to accomodate? For a family it's a lot harder to find something that's suitable. Need a big van to have the space a windup has when setup but in a windup you're still sleeping under canvas. Lot's of camper trailers are quick to setup if only flipping the lid, etc but start adding annexes for kids and setup time increases a lot. Lots of pros and cons for each type.
Any specific q's, happy to give my views :)
Cheers, Nige
AnswerID: 329096
Reply By: Member - Tom V (WA) - Thursday, Oct 09, 2008 at 18:51
Hi john
we have just purchased an offroad jayco dove(only one that would fit in the garage) as mentioned above u can raise the roof a couple of mm to open the door & get to the fridge. we also keep a AGM battery in the back of the prado & run the waeco. so we can u this as well.
the fold down table sounds like a great idea, i might look @ fixing one on the dove. the dove has a small side hatch u can open to get to the storage box under the seat.
we keep a small gas stove in here(the $25 ones from kmart with the WD40 size gas cyl) so we can make a cuppa or expresso.
looking @ the van, I would regard it as a SUV style not a true 4WD style. so i would not take to cape york. but other minor tracks it would do with ease.
good luck with yr choice. cheers Tom
AnswerID: 329102
Reply By: PradOz - Friday, Oct 10, 2008 at 09:58
hi john
each brand has pricing implications with jayco being the least expensive up to goldstream being the most (IMO).
you need to look for is the layout suits you and your family. i have a jayco swan and it is excellent for 5 of us and has room for sleeping 7 and extra in annexe as well. i went for jayco to save the extra initial cost on purchase and spent the money to put in the things i wanted as i needed.
i would make sure you can access the fridge from the camper door when it is down. great for roadside stops but even better is when you forget to switch the fridge over to 12V for travel you dont have to try worm your way thru your packed van to get to it. the jayco swan is setup for this, just reach in from the door and you are in the fridge. other brands have the similar layout if you were to choose them. if you pack inside the van with extra gear, chairs, tables etc the layout may restrict your accessing it for roadside stop. apart from that they are easy enough to get into if need be, just undo front catch, wind up slightly and you are in. If you want to wind it all way up would only take you couple mins, but the smaller campers may have the slide out beds in your way. My swan is large enough that i can pull the front bed forward about a foot and its right out of the way,.
you can access the other forums i mentioned in the post above this one (30th anniversary jayco post) and get advice from others.
my only other advice if you have a family is to get the largest one you can afford (and store and tow etc) so you have plenty of space and room when camping and packing.
cheers.....
AnswerID: 329197
Reply By: motor_head - Friday, Oct 10, 2008 at 19:03
Hi John, we have a coromal, roads like the Plenty hwy are a walk in the park for all offroad wind up campers, we took ours through cattle water pass to the east Mac's, this track has servere washouts and steep rocky sections etc, too easy....also took it over the mereenie loop road where we seen several jayco's, no damage to ours....as for the old telegraph track on the cape i wouldnt dare, too much drama and risk of serious damage, I was actually surprised how well ours stood up when we dragged it all over NT, i think the biggest concern would be broken springs or U bolts on bad corrigations, the rest of the camper seems pretty sturdy, we also carry a fridge, portable cooker and fold up chairs etc in the vehicle but pack anything you may need from the camper just inside the door and it is easy to get too. Deep water crossings are a bit of a problem but other than that i am happy with mine.
AnswerID: 329257
Reply By: Goona - Saturday, Oct 11, 2008 at 16:13
John,
I have a Goldstream Wing 11R and it has been great. We are currently doing a 7 month trip around Australia with a 4 year old and a 2 year old. We have done the Cape and yes we did both the Development road and the Telegraph track. We even did the infamous Gunshot but this apparently was pretty tame this year. I have had no problems with it to date except for a little damage through driver error. Hitting a post with he door of which I will get replaced in Melbourne at the factory. I have changed a few things like the tow hitch is 360 degrees in all direction, added another water tank, another gas bottle and battery along with charger inverter and solar panel as we like to get away from the caravan parks. Stopping for lunch is no drama as stated before just lift it 1cm and climb in but what we do is make our lunches prior to departure and put these into a little 18lt waceo in the car.
Alot of "Making it last" I put down to driver attitude. We let our tyres down about 25% on corrugations and this takes, as it does the car, alot of the impact out. We also slow down. Alot of people we see are going flat out and wonder why they are falling apart. Another thing to look at as we did when we bought ours was the warranty. Jayco said 1 year but if you take it off road you void it. Goldstream said 5 years where ever I wanted to take it. I mentioned Gibb river road, yep, mentioned the Cape, yep where ever you want. Sold us.
Goona
AnswerID: 329357
Follow Up By: Boobook2 - Sunday, Oct 12, 2008 at 10:11
Goona
OT
did you mount the solarpanels to the roof. Just interested if you know if you can screw into the roof withour damaging anything. I want to put my panels in a mount on the roof, and would want to screw into it. (easily removable so I can put away from van most of the time)
FollowupID: 596837
Follow Up By: Goona - Friday, Oct 17, 2008 at 23:59
Yes just found the supports and screwed away. Drilled a pilot hole first and put a heap of silicone around it to ensure no leaks.
FollowupID: 598027
Follow Up By: Boobook2 - Saturday, Oct 18, 2008 at 07:27
Brilliant, thanks
FollowupID: 598040
