Garmin Quest
Submitted: Friday, Oct 10, 2008 at 13:05
Zukscooter
Hi peoples, i have the above gps unit @ somehow managed to wipe the Aus map off the unit & cannot retrieve same.All i have is the usa map & where the garmin HQ are & no sat come up either.So hope some one can help.
Thanks in advance.
Bob.
Reply By: Robin Miller - Friday, Oct 10, 2008 at 14:19
Use one of those on my Trail Bike Bob , I'd be concerned about the no satellites first as without this the maps no use.
Any ideas on satellites , has flip aerial been disconnected.
The map can normally be re-loaded from your CN disks.
Does unit still work from internal battery ?
329216
Follow Up By: Zukscooter - Friday, Oct 10, 2008 at 16:26
Thanks Robin,does have flip but, no!No different with internal batteries.
I have reloaded maps but it just stays on the USA map with the pointer,pointing to Garmin Building .
Cheers Bob.
596553
Reply By: Member - Doug T (NT) - Friday, Oct 10, 2008 at 15:51
Try this
Image Could Not Be Found
329229
Follow Up By: Zukscooter - Friday, Oct 10, 2008 at 16:21
Thanks Doug it did not work.
Cheers Bob.
596552
Reply By: Ross H (QLD) - Friday, Oct 10, 2008 at 18:02
young Bob
I think it is just the garmin's worn out ......You have had too many holidays over the last 18 months and used it to much.
So just put in your dresser drawer and go back to work....:)
Hope that helps Bob
Take care
Ross
329245
Follow Up By: Zukscooter - Friday, Oct 10, 2008 at 20:11
G'day Bigfella,it is not worn out i am.No i have not had enough holidays as you say.Not enough room in that drawer.
Butt thank you for your concern of me having to work so much & waering out.
You'd better 'take care
Ross'as your reply helped me no end.Lol
Work hard Bob.
596612
Reply By: DIO - Friday, Oct 10, 2008 at 18:54
A suggestion....
Turn your unit ON
Push the MENU button twice
Scroll up or down to Map Info
Once map info is highlighted push the OK button
You should now be able to see which maps are loaded onto your unit.
If City Navigator is installed it should have a tick in the box to the immediate left of the map name. If not, using the up and down scroll button, move to the box next to City navigator (if you have more than one map installed) then push the OK button. You should now see a tick in the box. You can now return to the navigation screen and start navigating.
329253
Follow Up By: Zukscooter - Friday, Oct 10, 2008 at 20:12
Thanks Dio but that did not work either.
Bob.
596614
